      02-06-2024, 09:27 AM   #1
slowblackx3f25
xdriv33
slowblackx3f25's Avatar
Drives: 17' BMW x3 F25 xDrive28i xLine
2017 BMW x3  [0.00]
Lightbulb BMW N20 oil change
PSA:
When changing engine oil, please pour the entire 5L's in the engine.
(N20 engine).
Some people are pouring 4.8L's which is not enough.
Speaking from experience.
Only when we pour in the entire 5L's of engine oil, the oil sensor relays the appropriate engine oil level (right below MAX).
Otherwise, it is below the MIN mark which requires more oil to be poured in.
Not sure if this was mentioned here already.
BLACK 2017 BMW x3 xDrive28i [N20] xLine Package, Comfort Access, Build Date: 03/03/2017. *[THE POWER OF 33]*
      02-06-2024, 12:41 PM   #2
JD007
Drives: 17 BMW X3
I’ve pour 4.8 L from the 5L liquid Moly Molygrn 5w-40, and the mark sit at max, so, u recommend that I pour the rest????
      02-06-2024, 12:43 PM   #3
JD007
Drives: 17 BMW X3
Btw, first pic is really cool, where does that info is in idrive?, or maybe it’s for Xdrive only???, mine is sdrive same year 2017
      02-06-2024, 02:55 PM   #4
Opie55
Drives: '15 650i Convertible
Hmm, from BMW's official specs I've read, the N20 takes 5.1 quarts. Being the fastidious person I am, I have always added the extra tenth.
      02-06-2024, 07:08 PM   #5
pungo
pungo's Avatar
I typically follow the TIS for oil capacity since that info comes from the manufacturer of the vehicle, who should know the correct amount.
Reading the internet, I've seen as least 5 different capacity amounts
From the TIS:
Oil supply N20 / N26
  • Capacity, engine oil change with oil filter element without all-wheel drive - Liter 5,0
  • Capacity, engine oil change with oil filter element with all-wheel drive - Liter 5,50
Oil supply N55
  • Filling capacity, engine oil change with oil filter element - Liter 6,50
      02-06-2024, 09:51 PM   #6
Opie55
From the TIS:
Oil supply N55
I just looked, and you are correct. NewTis was also my source for 5.1 quarts, but 5.5 liters is 5.8 quarts. Who knows where I was looking.
      02-07-2024, 10:14 AM   #7
slowblackx3f25
xdriv33
2017 BMW x3  [0.00]
yes, the entire 5L's.
I did pour 4.8L but it's not enough, the oil level is under "MIN" when I pour 4.8L's, so I pour the entire 5L's and it's above "MIN" and under "MAX" when I check oil level again digitally.
      02-07-2024, 10:17 AM   #8
slowblackx3f25
xdriv33
2017 BMW x3  [0.00]
Yes, useful information regarding the surface the X3 is on.
Not all gas stations have flat surface...
It's a "X-Drive" option. It's under "X-drive status". See if you can find it, but your's is S-Drive (RWD), so you might not have it...
      02-07-2024, 10:19 AM   #9
slowblackx3f25
xdriv33
2017 BMW x3  [0.00]
From the TIS:
Oil supply N55
Yes, I've found different oil capacity listings all over the internet.
I will refer to BMW TIS instead. The WWW can have false info. Go directly to the source (BMW TIS).
      02-07-2024, 10:21 AM   #10
slowblackx3f25
xdriv33
2017 BMW x3  [0.00]
I'm not adding 5.5L's.... unless the BMW iDrive system tells me to add more than 5L's.. even though mine is AWD(X-Drive).
      02-07-2024, 10:49 AM   #11
pungo
pungo's Avatar
Yeah, trust your 7 year old electronic sensor over what the engineers at BMW recommend
      02-07-2024, 12:27 PM   #12
slowblackx3f25
xdriv33
2017 BMW x3  [0.00]
ahhh now you got me thinking well it's better to add than subtract, I'll add the .5 and see what happens, if it goes over "MAX", time for a new up-to-date sensor... and drain a little bit of engine oil?
      02-12-2024, 10:58 PM   #13
JamesInSJ
Drives: E46 M3
I've only had to do one change on mine so far since buying it, poured the full 5 quart and the oil measured right at the max line, and hasn't budged off it in 4000 miles. 2013 X3 xdrive28i / N20.
      02-13-2024, 07:57 AM   #14
slowblackx3f25
xdriv33
2017 BMW x3  [0.00]
Only if there was an ACTUAL OIL DIP stick we can use to measure accurately. Because how accurate is the engine oil sensor???
      02-18-2024, 10:36 AM   #15
slowblackx3f25
xdriv33
2017 BMW x3  [0.00]
and I realized you should be doing an oil change soon 4000/4500 miles is about time for an oil change, I don't go past 5000 miles...
      02-26-2024, 05:02 AM   #16
GiorgiP
GiorgiP's Avatar
Georgia
Drives: BMW X3 xDrive28i (F25)
Just recently Purchased 2015 X3 xDrive28i from Copart.
The car has 92K miles and as I don't know when the last oil change was done, I am planning to do it myself.
The owners Manual says that if i use Valvoline (The Best option in my Country), I should aim for 5W-30.
But on the Valvoline's web-page, when I enter the details of my car, it recommends 0W-20.
What's your experience?
My country has a climate where in Summer temperature can go up to 45C (113F) and in Winter to -10C (14F).
      02-26-2024, 05:55 AM   #17
Jolbex
Drives: X3
In our country (-25⁰ to +40⁰) bmw service filled 5w30 to my 40i
      02-26-2024, 08:15 PM   #18
slowblackx3f25
xdriv33
2017 BMW x3  [0.00]
5W30 all year around.
      02-27-2024, 02:34 AM   #19
GiorgiP
GiorgiP's Avatar
Georgia
Thank you guys, helped a lot really.
Another question here if possible:
There are a lots of discussion about whether to change Transmission Oil or not. What's your experience?
Mine drives really good without any problems and I want it to continue this way, so should I change or leave it alone?
Don't know whether it was changed by previous owner or not, I'm planning to acquire Carfax history but what is the general situation towards that subject?
      02-27-2024, 05:52 AM   #20
Jolbex
Drives: X3
Would only do it if planning to keep the car over 100kkm. Would do it at some 60 or 90kkm IF i found decent mechanic since bmw service is too expensive. Know a few friends with bimmers over 150kkm and trans oil never changed...
      02-27-2024, 04:37 PM   #21
pungo
pungo's Avatar
If you care about the transmission health, change it at the ZF recommended intervals. It's not changing all of it since much of the old fluid remains in the system. By not changing it, the filter fills up with junk. If you wait until the trans has problems, you've waited way too long
      03-04-2024, 05:22 AM   #22
GiorgiP
GiorgiP's Avatar
Georgia
Thanks again, appriciate.
