      08-12-2020, 03:15 PM   #1
Romanian nightmare
Romanian nightmare's Avatar
Drives: 2020 X5 M50i Alpine Weiss
X3 Cross bars issue
Hello all,
I have a 2017 X3 and recently bought the crossbars to add/use a Thule box on long trips. First time use and the front right locking mechanism stopped working. The screw/bolt that is supposed to tighten the lock, stripped and now I cannot use it. Of course, Murphy's Law kicked in full force and this happened the morning we were leaving for the beach. I ended up getting it as close as I could, used some small pieces of wood to get it tighter between the rail and the carrier, and ultimately I ended up using tie wraps to secure it.
Now, I'm looking to replace the stripped special bolt. I cannot find any info or sellers of this bolt. I have called the dealer and they are searching too. I can't imagine that if this bolt is stripped, it will render the whole cross bar system useless and the only option is to buy the whole set again for nearly $250.
I will try to post some pictures later, but any input on this dilemma, would be greatly appreciated!
Thanks in advance!
Cheers!
      08-12-2020, 03:45 PM   #2
raddoc
Drives: X5,Model3,M240i
Solution
Three ways to go:
1. Helicoil if hole threads are bad.
2. Tap new thread or find new SS screw. Most Ace hardware stores have a reasonable selection.
3. Machine shop
None will cost $250
      08-12-2020, 04:03 PM   #3
Romanian nightmare
The dealer called and they do not have replacement parts for this accessory.
So at this point, I'll search for a shop to make one at least similar so I can use the expensive BMW accessory!
      08-12-2020, 04:17 PM   #4
Romanian nightmare
Originally Posted by raddoc View Post
Three ways to go:
3. Machine shop
None will cost $250
Thanks for the suggestions. i'll have to look into the Helicoil option
      08-12-2020, 05:10 PM   #5
6MT_Addict
6MT_Addict's Avatar
Drives: 08 135i M Sport 6MT, 15 X3 35i
2008 BMW 135i  [10.00]
Originally Posted by Romanian nightmare View Post
Hello all,
Thanks in advance!
Cheers!
What stripped? The bolt or where it threads into?
I'm not familiar with the roof rack clamps but if it's just a stripped bolt figure out the thread pitch and bolt size, and get a replacement. Won't be more than a few bucks.
2015 Cosmic Blue Metallic Wrapped X3 35i ///M Sport
Full 3M Vinyl Wrap | Flat Black Grilles
      08-12-2020, 07:51 PM   #6
najnad
General of the Space Forces
najnad's Avatar
Drives: 11 X3 35i M-sport
There is probably a few boxes in China with the special bolt in them, but of course they are not for sale....
      08-13-2020, 06:51 AM   #7
Msportdriver1
Drives: X3 35d M sport
The BMW crossbars are just re badge Thule , you could try thule direct, or replace bolt etc as previously suggested.
      08-14-2020, 10:18 AM   #8
Romanian nightmare
Well....I found a magical machinist at my work and he was able to re-thread both nut and bolt and will try it tonight.
Still amazed that there are no replacement parts, and I'm sure people have bought new systems because of it.
Cheers!!!
