08-04-2020, 03:50 PM | #1 |
Rep 15
Does F25 35D have swirl flaps? Fault error
Hi all,
So I've had my F25 35d for a few days, it's a 2011 model with 56k on the clock but has been stood intermittently for a few months since its previous owner passed away. Upon the drive home (100 miles) it threw some codes on not being able to monitor tyre pressure and the ABS being switched off (presuming previous owner blew them up but didn't reset the comp). Anyhow after clearing those it's throwing up a 'drive moderately message' intermittently. It only occurs when the car's been running for over about 30mins and then goes out 10mins later. Running Carly the major errors it's listing are:
It seems these issues are linked to the swirl flaps? But does the F25 engine (N57D30T1) have swirl flaps? I've removed them before on early 3.0.L D cars but thought the later engines didn't have them. Any insights appreciated. The engine runs quiet and smooth, so I'm hoping a minor issue due to lack of use/carbon build up. Also is the EGR in the same place as the M57 engine (top front right) or lower? I'm wondering it removing it and maybe the intake for a clean may help the issue.
35D M Sport (F25)
318 saloon (E46) Last edited by Alchemisty; 08-05-2020 at 10:30 AM.. |
08-05-2020, 10:01 AM | #2 |
Rep 1,044
A lot of times a low battery situation can cause false codes to appear.
2016 Z06 Vette, 10.53@132
1984 Vette, 406, 10.23@131 2021 SQ5 |
08-05-2020, 10:28 AM | #3 |
Rep 15
382vett that's v interesting and useful, as the auto stop/start function only started working yesterday as well and i had a start problem a few days ago. It was reading under 12V when stood and then 14.5 when running
Gonna swap it to be on the safe side
35D M Sport (F25)
318 saloon (E46) |
08-05-2020, 10:33 AM | #4 | |
Rep 4,337
In any event, I would suggest you recharge it, they don't like sitting for long period and tend to degrade since the car is alway on in some minor state. Example: it still watches for someone to place their hands on the door handle (comfort mode) and is ready to lock/unlock when that is done and in order to do this, it uses battery power. That's just one example, so over time the battery degrades. Give it a good charge for a couple of days and see if your errors disappear and if not, you may need to replace the battery. |
08-05-2020, 11:22 AM | #5 |
Rep 15
Cheers Marty, gonna replace it anyway for piece of mind. About to take the car on holiday and will be kicking myself if this is the cause of a few gremlins that plague the journey. I intend on keeping the car, so would rather replace now as expect it will need swapping anyway during its ownership with me. Just ordered one, will pop it on and code it in and see what's what. I think the auto start/stop only just starting to function is a giveaway it could be low
35D M Sport (F25)
318 saloon (E46) |
08-05-2020, 11:31 AM | #6 | |
Rep 4,337
Have a great holiday and lets hope your issues are simply the battery! |
08-05-2020, 12:09 PM | #7 |
Rep 15
Cheers Marty - best I've had is ten years so I'll bow to your 14 innings! Will rpt back if any issues. So pleased I joined this forum!
35D M Sport (F25)
318 saloon (E46) |
Marty in NY2723.00 |
