07-31-2020, 07:41 AM | #1 |
Rep 15
Newbie with 35d and spare wheel options
Hello, to you all!
Stumbled across this forum as about to pick up a 2012 35d M sport this weekend which I'm v excited about. I'm not new to BMW ownership having owned E36/46 models and currently an X5 (E70) that's making way for the X3 (plus an 1999 e46 318 for daily duties). As I have done with the X5, I plan on getting a full size spare wheel for long distance work (as I tow a caravan on holiday), and the X3 I'm getting looks to have a staggered 19" set up. I'd be keen to get your thoughts on what I can run as an all round spare, should I get one that's the same size as the front (8.5j) as apposed to the 9.5 rear?
35D M Sport (F25)
318 saloon (E46) |
07-31-2020, 10:12 AM | #2 | |
Rep 4,333
07-31-2020, 11:08 AM | #3 |
Rep 350
If you end up getting a full size spare, it must be the same size as the front. Even with a staggered setup, front to back has approximately the same rolling diameter. However it's unlikely the wide rear tires will actually fit up front without rubbing due to the width. Also be aware that running a wheel sized for the front in back should be treated as temporary and a proper one should be placed there as soon as possible.
07-31-2020, 03:20 PM | #4 |
Rep 888
Drives: 08 135i M Sport 6MT, 15 X3 35i
This ^^^
Also check wheel size and offset. For example if you have the M sport package with upgraded front brakes the smallest wheel size you can fit is 18". A 17" wheel will bind on the larger caliper. Handy link: https://www.wheel-size.com/size/bmw/x3/
2015 Cosmic Blue Metallic Wrapped X3 35i ///M Sport Full 3M Vinyl Wrap | Flat Black Grilles |
08-01-2020, 03:37 PM | #5 |
Rep 15
Thanks chaps - this is great advice. Picked the car up today, what a machine! Drives more like my old E46 M sport touring than my X5 E70!).
Anyhow on the wheels, got home and popped them all off, greased the flanges (as all were binding a little and not easy to tease off) and tried a front wheel on the rear. Good news is the flange is the same size, hence my plan is to get a full size 19" the same as the front (as you suggest) and use it as a spare for long journeys, if it will stand up in the boot next to the dog cage I'm sorted. Also great to see the scissor jack I carried for my E70 (from a MkI X5) works perfectly on the X3 too, hence with a spare wheel I'll be sorted.
35D M Sport (F25)
318 saloon (E46) |
08-01-2020, 04:50 PM | #6 | |
Rep 4,333
08-01-2020, 05:09 PM | #7 |
Rep 2,547
Make sure you're able to secure the spare in the boot with something sturdy enough so that it doesn't become a deadly projectile in an accident. My friend is a first responded and he's seen things lighter than a wheel break though the rear seat backs and hit the passengers up front causing near deadly damage to them. That's why they're secured with a large fastener.
08-02-2020, 02:37 PM | #8 |
Rep 15
Thanks Pungo - that's a good tip which I'll follow. Even considering making a dedicated board for it and clamping it to the roof bars.
Marty - yes - not far from me! A good friend lives in a village just outside it
35D M Sport (F25)
318 saloon (E46) |
08-02-2020, 04:40 PM | #9 |
Rep 4,333
Loved it there. There's a pretty good sausage deli in Beckenham on High St called villagers fine sausages (used to have a diff name when I lived there) and an interesting Indian restaurant in Bromley called Tamasha's. We went there frequently.
