07-01-2019, 04:53 PM | #1 |
You live by the sword...
216
Rep 8,244
Front PDC sensor wire cut...dealer wants 1k to fix
How difficult is it to replace the wire myself? The dealership quoted me over 1k to replace the cable...here's an image of the damage to one of the front sensor wires:
07-01-2019, 05:21 PM | #3 |
216
Rep 8,244
07-02-2019, 05:49 AM | #5 |
Rep 120
While I have no direct experience with this particular connector, many connector shell halves are two piece that come apart. You'll need a small screwdriver to pry the shell apart and a wire piercing type continuity tester to push the contact out. I'd try and separate what appears to be the female side of the connector into it's separate parts and then remove the contact holding the damaged wire. If you can do that, making a good wire/contact connection is pretty easy. Once it's fixed, reinsert the repaired wire/contact, reassemble the shell half, and put a dab of silicone caulk on the contact where it enters the connector core to ensure it's weather proof. Good luck.
Pat
2015 F25 X3 35i M Sport - Carbon Black |
07-02-2019, 11:27 AM | #6 | |
Rep 482
Pretty easy to fix. Once you separate the shell you need a pointed tool to pull out the pin. The pin is either soldered or crimped to the wire. You can find those crimping pins either on line or probably electronic shops. BMW has also a kit and ECS and other vendors carry them. GL
Stable:
e92is f25 N52 e83 N52 e46ci M54B25 (e53 N62 - sold, R.I.P. e39 M54B30) |
3onDubs216.00 |
07-02-2019, 07:10 PM | #7 |
Rep 1,044
Unfortunately, dealers are not paid to improvise. They would rather replace the whole harness after removing the bumper than repair the connection. That's how they make $$$.
2016 Z06 Vette, 10.53@132
1984 Vette, 406, 10.23@131 2021 SQ5 Last edited by 383vett; 07-02-2019 at 07:16 PM.. |
3onDubs216.00 |
07-03-2019, 11:22 AM | #8 |
Rep 80
Here you go
https://www.ecstuning.com/b-genuine-...g/61132359997/ Probably enough slack to trim the ends of the wires back a little and crimp on the new connector. |
3onDubs216.00 |
07-03-2019, 01:53 PM | #9 |
Rep 1,538
get a new plug or a salvage one is a crazy easy and cheap job.
Can't believe BMW would bill 1k for a non-critical sensor , how they get customers? They can quote something more realistic, like 200$, still make 300% profit and at least get the job... |
3onDubs216.00 |
07-03-2019, 05:38 PM | #10 | |
216
Rep 8,244
ya, they even charged me for the push pins to put the bumper back on after examining the wire |
07-04-2019, 08:09 AM | #11 | |
Rep 71
BTW, they shouldn't have needed to replace the push pins if they didn't destroy them when they removed the bumper. They can be reused. |
3onDubs216.00 |
07-26-2020, 08:33 PM | #12 | |||
Rep 4
Did you happen to fix the problem? I have something similar but it has to do with the actual plug seems that it has corroded inside from moister. I bought another PDC sensor thinking that was the issue but sadly not, I may just buy another plug cut the existing wire and electric tape the new one. |
