10-18-2018, 11:18 PM | #1 |
Rep 123
2017 X3 Headlights upgrade options
We are looking into buying an used 2017 X3, but the vast majority of car that we like / low miles come with halogens....
Are there aftermarket LED / HID solutions that are simple to install and doesn't require a lot of retrofitting? I am familiar with coding so there is at least that. |
10-19-2018, 07:40 AM | #2 | |
Rep 2,036
I made that mistake when I got my F31.....fortunately I spent $500 on a set of Depo aftermarkets and upgraded.
10-19-2018, 09:06 PM | #4 | |
Rep 123
Every VIN that I decoded comes with that package, but the headlights are clearly reflectors. I think the Package name is XENON, i did the VIN of a X4 which the halo / projectors and it showed that. |
10-20-2018, 07:30 AM | #5 | |
Rep 2,036
The exterior lighting package is usually a$1900 option. Upgrades halogen to bi-xenon or to LED adaptive.
10-24-2018, 10:28 AM | #6 |
Rep 679
You will never get the quality/integration (auto-leveling) aftermarket - keep looking....
And yes, this was a mandatory option when I was looking, no more halogens ever... |
10-25-2018, 04:17 AM | #7 |
Rep 547
Yupp. Halogen to Xenon is one of the few upgrades that are not possible or is highly cost prohibitive to the point that it's cheaper to change car.
Previous Bimmers: F25 X3 20d LCI xLine, F30 320d Luxury
10-25-2018, 02:47 PM | #9 |
Rep 2,036
Which websites you using to search and what's your budget?
03-16-2019, 10:35 AM | #11 |
Rep 2,547
I'm in the same boat, every time I find a low mileage vehicle with all the options I want, it has halogen. I definitely want to get Xenon that were installed from the factory and not try to retrofit anything. I use a VIN decoder and just make sure it has the Xenon option. I'm sure eventually, if I look long enough, I'll find what I'm looking for, I will not settle for anything less. Good luck with your hunt.
03-16-2019, 02:09 PM | #12 |
Rep 123
I ended waiting and finally got a 17 CPO with HIDs.
Wouldnt want it any other way, they look fantastic. I might change the bulbs for some Osrams 5k later, but so far so good. |
04-14-2019, 09:03 AM | #13 |
Rep 2
07-27-2020, 03:19 PM | #14 | |
Rep 2
Same issue
New to the boards - currently looking at 2017 X3s and every one that has the majority of the features I want, they all lack the lighting package. What did you end up getting? |
07-28-2020, 07:26 AM | #15 |
Rep 45
There is no inexpensive option for updating lighting options for the X3. I researched updating mine when I realized how bad the halogens were. My ultimate solution was to buy aftermarket H7 bulbs. I bought Hella H7, 100 watt bulbs that provided an acceptable solution. Not perfect, but provides adequate lighting without coding. The problem with LEDs is the reflector housing is not designed for them and the lighting pattern gets messed up. Check your local laws before using the 100 watt bulbs. They may not be legal in your area.
Doug
2019 BMW 430 XI Grand Coupe, White, Black leather interior 2016 BMW X3, 28d, Mineral White metalic, Oyster Nevada leather interior. |
07-31-2020, 11:33 AM | #16 |
Rep 350
If you're looking primarily at the 2017 28i/28d models, the halogens would have been the standard equipment. The car would have to have been ordered with the ZLP Lighting Package to receive upgraded lighting.
The 35i models came standard with xenon HID lamps and adaptive light control. The lighting package on those cars changes it to adaptive LED with automatic high beams. ============================= X3 sDrive28i, X3 xDrive28i, X3 xDrive 28d ============================= Standard Halogen ZLP Lighting Package (low) S522A Xenon headlights S524A Adaptive light control Also adds rear LED tail lights ZLP Lighting Package (high) S552A - Adaptive Full LED Lights Also adds rear LED tail lights ============================= X3 xDrive35i ============================= Standard S522A Xenon headlights S524A Adaptive light control LED tail lights ZLP Lighting Package S552A Adaptive Full LED Lights (upgrade from Xenon) S5ACA Automatic high beams LED tail lights |
joshaguirre13.00 |
