01-29-2012, 04:21 PM | #1 |
Rep 32
AC and Efficient Dynamics
I've read about Efficient Dynamics and the fact that my F25 is smart enough to only engage the alternator when the battery needs charging. I've also noticed that when I put the climate control in Auto mode then the AC snowflake light is always on. Does this mean that the AC compressor is always engaged when in Auto mode, e.g., even when it is below freezing outside? Or does the Efficient Dynamics approach somehow also apply to the AC?
01-29-2012, 06:44 PM | #3 |
Rep 32
So snowflake light on means compressor engaged and impacting gas mileage, so don't press the Auto button in winter unless the windows are fogging. Sound right?
01-29-2012, 06:47 PM | #4 |
Rep 25
In winter AC ON means that DRY air is circulating so that the windows don't get foggy...
However, I am wondering myself if this process requires more energy... |
01-29-2012, 07:09 PM | #5 |
Rep 32
Yeah, that's where my question is coming from. Drying the air means "conditioning" it with the AC and then heating it with the heater, so I'm thinking snowflake light on means a hit on mileage.
01-30-2012, 06:55 AM | #6 |
Rep 32
How can the compressor run very little yet still continuously dehumidify? Does the climate control system have a humidistat? If not, it would seem that the defogging would be intermittent.
01-30-2012, 07:12 AM | #7 |
Rep 876
On all our vehicles with auto climate control we have always disengaged the A/C compressor via the 'snowflake' button during the colder winter months to avoid unneeded parasitic loss. We only activate the A/C compressor when we need to defrost the inside windows.
And as far as I know you are only dehumidifying when the compressor is engaged and actively running. When the compressor is out of the loop you are simply moving air around. |
01-30-2012, 09:52 AM | #8 | |
Rep 233
The climate control systems in today's vehicles are refined automatic systems designed to control temperature and humidity under almost all conditions and these systems do it well. Typically, above 40 degrees F or so the compressor is used in a reheat cycle to control humidity. Below 40, just the warming of the air will lower the dew point sufficiently for a comfortable humidity and the systems are smart enough to not run the compressor (same reason a humidifier is required during winter months when heat is used). In any case, manually turning off the compressor is only saving pennies and not allowing the system to work as designed. The X3 and similar vehicles are certainly not inexpensive. However, we manually defeat an automatic function that only might save pennies after spending a lot of money for the fine engineering behind these systems and the creature comforts these systems provide. Not sure I understand the logic. One last thing. Universally, the snow flake light only means the system is enabled to run the compressor. It does not mean the compressor is engaged continuously while the light is on. Except under conditions of very high heat load, the compressor is always cycling to prevent the evaporator from freezing up but the light remains on continuously. BTW, the compressor is not cycled to control cabin temperature, the amount of reheat takes care of that function. |
01-30-2012, 11:43 AM | #10 |
Rep 876
I certainly don't disengage the compressor for financial gains, although every little bit helps, I keep my compressor off because when it is on I feel a slight drag in my vehicle which is normal and minor but none the less it is there. I also don't believe the automated systems are as smart as some believe. I could be wrong but I don't think our X3, or any other vehicle in our fleet, measure cabin humidity levels and are smart enough to cycle on and off when our windows get fogged over.
If the fuzzy logic behind the auto climate control was well defined then there wouldn't even be a button to turn the ac compressor on and off it would be in AUTO mode always. BMW, as well as pretty much every other car manufacturer out there, recognizes the need to permanently place the compressor in a persistent OFF mode due to many factors thus the availability of the button. I personally like to be able to engage and disengage various accessories when not needed especially when there is a direct correlation to my vehicles performance and efficiency. |
01-30-2012, 01:24 PM | #11 |
user
Rep 229
Maybe you should remove the pulley from the compressor and install a shorter belt in the winter.
Actually, it would probably be best to remove the entire a/c system in the winter to shed the 40 or so pounds of useless weight - imagine the performance benefits on your trips to the mall. |
01-30-2012, 02:10 PM | #12 | |
Rep 876
Gosh, I can see it now, the windows fog over on my wife's X3, she pulls over on the highway and struggles to crank on the belt tensioner to give her enough slack to lift the shorter belt off and replace with the std length belt so the ac compressor can spin up and defog her windows. After she does that a few times I'd give her the junior mechanic label!! ;-) In the end though you are right, whether you are mechanically eliminating the ac compressor from the serpentine loop all together (via a shorter belt) or you are simply pressing the ac compressor on/off button on the dash the end results should be the pretty much the same, no parasitic loss. Just a slightly different level of involvement to reach the same goal. |
01-30-2012, 02:15 PM | #13 |
user
Rep 229
I don't know - just pushing the button means you are still spinning a superfluous pulley; only the compressor clutch will never engage.
01-30-2012, 06:32 PM | #14 | |
Rep 233
Each of us certainly has the right to do what we want with our vehicles. However, imo, regardless of the rationalization given, there is not a single consequential engineering reason either from an economy perspective or performance perspective to ever disable the compressor. By performance I mean both the ability of the system to control the cabin interior climate and the performance of the vehicle both in terms of efficiency, acceleration, and braking. If it just makes one feel better not seeing the snowflake lit then admit that is the reason. If vehicle performance is the issue, then only at full throttle acceleration will one see a minor difference and then, at full throttle, the gasoline being sucked up is more than negating the small economy of not running the compressor. That being said, there is indeed sometimes a good reason for overriding an automatic function. IMO, all vehicles I have had with automatic climate control, without exception, do not do a good job deciding when to switch from recirc to outside air. On hot days they invariably come off recirc too soon. I also like it really cold with the least fan noise. Therefore, if the temp is in the high 70s F or greater, and there is a significant sun load on the car, I always force recirc. To me, it feels colder and drier when I do this. I also suspect much of this is in my head, and I paid for the car, so I do what I want, at least until my wife complains. |
