      04-25-2011, 03:44 PM   #1
kmedina
Loves BMW
kmedina's Avatar
Drives: X3 28i
Garage Door Openers
I was trying to add a gate opener into one of the three slots to no avail. The owner's manual mentioned something stating I would need the manual for the gate opener if it did not work. Does anyone know what I should do or has anyone else encountered this issue? Thank you.
      04-25-2011, 05:50 PM   #2
Nahoa
If it's like the coded garage door openers, you might need to know how to get the motor for the gate to enter "learn" mode or some equivalent. On my garage unit there's a button you need to press on the motor unit (vice remote) and then do the shenanigans in the car to get the two working. Dunno if that helps . . .
      04-25-2011, 06:01 PM   #3
Radioactive
Drives: '11 X3 28i '10 535i '04 325i
Dunno if that helps . . .either, but here's HomeLinks web page.
http://www.homelink.com/home.php
      04-25-2011, 07:45 PM   #4
LEDZEP
LEDZEP's Avatar
417
Drives: 2009 E70 & 2011 F25
If it's a rolling code (probably is) you'll need to "learn" it, as mentioned above. Do the members a favor when you figure it out and post the instructions.
I think it is bad luck to be superstitious
      04-25-2011, 09:41 PM   #5
MB330
MB330's Avatar
52
Drives: 330i
2018 BMW 330i  [0.00]
2006 E90 330i  [10.00]
From my personal experience with 330i home link.
Make sure you original remote control has fresh battery - spend 45 min first day get her home (engine idle, remember in BMW you can't use home link if engine is off, same as horn) try to think my garage opener with my new car.
Nissan and Acura take about 3 min - but BMW
Only when I change battery, was able to think. And yes, rolling code - don't forget rolling code. I have to search E90Post for my original post.
Good Luck!
'06 330i Monaco Blue/Gray/Walnut/ZPP/Navi/CA/AT -->ED 2006
'18 330i Estoril Blue Metallic/cognac/AT/Sport
      04-25-2011, 10:10 PM   #6
Alanintx
ATAP
Alanintx's Avatar
Drives: 2017 Midnight Blue 430xi GC
Most residential security gates for multi-unit developments do not have rolling security codes.
The home link will generally work. You just have to follow the instructions TO THE LETTER. If it fails the first time, reset/clear the home link (push in the 2 outside buttons?) and start over.
For some weird reason, I was only able to get my gate opener to work with the middle of the 3 buttons.
      04-25-2011, 10:15 PM   #7
jijioben
Drives: 2011 F25 X3 35i
For me, it all worked in the end. But I noticed two things: first, the position of the remote control in relation to the receiver makes all the difference. I could not program the rolling code the first time, because the car's receiver did not catch the remote's signal at all. I experimented with many distances (like the manual said) and I finally got it. Second, because mine was a rolling code, I also had to set my opener to the "learning mode" and within 30 seconds press the button I programmed three times. After that, it worked consistently.
      04-26-2011, 05:48 AM   #8
LEDZEP
LEDZEP's Avatar
417
The trick when programming BMW's Homelink with a remote is to hold the remote between the windshield and the rearview mirror, pointed toward the mirror. This will save you a lot of aggrivation, and works the first time.
      04-26-2011, 07:59 AM   #9
Brutus1
Drives: 2011 x3 -Alpine white
Just wondered. Does it matter if I reverse in the garage but may not open the door until I am backing up and not facing the garage door with the "homelink"? I don't have to point my remote directly at the door so I assume I would not with this.
      04-26-2011, 08:04 AM   #10
bekind
Drives: x3 35i
No nothing needs to be pointed anywhere for homelink to work. We use ours from probably 30 yards out with no problem.
      04-26-2011, 01:50 PM   #11
sblove
sblove's Avatar
Drives: 2011 BMW X3 28i
I believe the instructions for programming a "rolling code" garage door opener are in the manual. I remember using the manual to pair my car with the garage door. One person did have to be inside near the motor to press the "learn" button. If this does not help, I can try and check my manual for details and report back.
      04-26-2011, 05:09 PM   #12
jijioben
You're right, but the manual is not precise enough. I did manage to program the rolling codes in, but it took some trials (see post from LEDZEP).
      04-27-2011, 05:56 PM   #13
kmedina
Loves BMW
kmedina's Avatar
Drives: X3 28i
Thanks for the tips. I will try them this weekend and let you know how it goes. DS and I have been sick, so we have not left the house this week.
      04-30-2011, 11:34 PM   #14
kmedina
Loves BMW
kmedina's Avatar
Drives: X3 28i
Tried again. No luck. Cannot enter learn mode, since there is a lock on the main gate opener.
      12-12-2011, 01:49 PM   #15
gmazet
gmazet's Avatar
308
Drives: Broken 2020 M2C
it was giving me fits programming, I'll try it again with led zep's technique..
Gary
Current: 2020 F87 LBB|Exec|DCT|slicktop
Other: 2017 F15 35i,|MPPK, 2012 F25 28i
Past: 2008 E92tt 6MT, 2001 E46 6MT 2009 Z06 1997 Camaro SS 6MT
      12-12-2011, 09:17 PM   #16
XB101
Drives: 2011 TiAg X3 35i
I got the homelink to work. I also have a key pad by the garage door outside and that is working. However the two remotes that came with the house do not work once I set up the other two device. Good enough, don't have the patience to get them ALL working. I do have the rolling code opener.
      09-11-2017, 10:06 AM   #17
Regans12
Drives: bmw
I have got garage door repair bellflower for work and installed the garage door opener with the key fob. Now i won't have to push the button for more , i can easily access it through remote.
