      06-03-2013, 07:24 PM   #1
HighPlainsCruiser
HighPlainsCruiser's Avatar
22
Drives: 2013 X3 XDrive35i
Check Bicycle Fit First
Using the bike rack first designed by sk330i and shown at http://www.bimmerfest.com/forums/sho...177&highlight=
in July 2011, very nice, total cost under $30 + fork blocks $15-$25 each. One thing to realize is if you have a 29" mountain bike and you like to raise the handle bars with extensions you may have to remove the handle bars to fit the bike inside. My mountain bike will not fit inside. I've also lifted the handle bars on the road bike a bit, it will fit if the handle bars are loosened and turned inward.
Non-Sport
All Options Except Lane Change Warning and Cold Weather II
Car Name: Princess
      06-03-2013, 07:54 PM   #2
sk330i
Drives: X3
What size is your road bike? Mine is 52 & my wife's 48 and they both fit inside my E83 without loosening the handle bars. Also, can you compress the front suspension on the mountain bike while transporting it? Perhaps that will give you enough headroom to clear the handle bar?
      06-03-2013, 10:07 PM   #3
HighPlainsCruiser
22
The mountain bike is a 17.5 frame, the road bike is a 58. Springs don't collapse. The road bike is the most important to carry securely. I can survive by laying the mountain bike flat. If it was a long distance mountain biking trip then serious dis-assembly could be done.
      06-04-2013, 07:44 AM   #4
raleedy
Drives: 2016 228i 6-speed
Boy, that's totally unacceptably for me. My 58cm road bike goes smoothly into my E92 with just the front wheel removed. Loosening the handlebar on the stem is not just inconvenient, it's dangerous.
      06-04-2013, 08:10 AM   #5
Schmed
Schmed's Avatar
Drives: E30M3, E70X5, F25X3
Wow - you have a LOT of spacers on the steerer tube. At least 3.5" more than most bikes would have.
I haven't checked my 29er fit inside, but I did fit a 54CM cyclocross bike inside yesterday. Like you, I had to remove the seat, but otherwise, it fit nicely.
2013 X3 3.5 | SAP | DHP | NAV | CWP | AW | Mojave
      06-04-2013, 10:01 AM   #6
Crash Test
Drives: 2013 BMW X3 35i
Seems you also have to remove the seat?
      06-04-2013, 11:04 AM   #7
HighPlainsCruiser
22
It is an extreme amount of spacers, if the bikes were more conventionally outfitted they would probably fit OK. - I definitely retighten the handlebars before proceeding. - The seats have to be removed.
Non-Sport
Car Name: Princess
      06-04-2013, 11:45 AM   #8
Schmed
Schmed's Avatar
Although not ideal, I'm sure the bike would fit in the backseat as it did in my E90....
- remove front wheel
- from the driver's side, put the rear wheel in first and it'll sit in the rear passenger-side foot well
- use a blanket to protect the leather
