04-10-2013, 03:48 PM | #1 |
Owner
132
Rep 566
Drives: G05 30d M-Sport
Manual box, little nag: getaway
I've now done 2500 miles, and I'm 98% happy with the gearbox -- the fact the regime change varies with the 'mode' the car is in, and that the output power is proportional to the "will" I put in the accelerator is pretty amazing and very fun.
I tried a few 'hot rod' starts and it's really amazing, I barely have time to change gear in sport mode before I reach 4k rpm, and that thing /pulls/, even the lowly 20d :-) *however* I have a nag. I can't seem to get a clean, soft, smooth getaway from 0mph in first gear. If I gently lift the clutch and gently add power, the best I can get is a bit of a jerky "hesitation" for a second or so before it stabilizes. Of course I tried a lot of 'variations', and I've driven many, many manual boxes/clutches before and usually I get the sweet spot in a matter of minutes... Now If I release the clutch gently by itself, I can hear the engine rev up a notch, the car gets to like 3mph, and then I can accelerate but there'll still be a 'hit', it won't be smooth. That clutch behavior is nice in traffic, but still I can't manage a 'smooth' start, and after 2500 miles, I would have assumed it would have bedded in by now... So anyone has a tip? is it software throwing my instincts out if kilter ?
Received 190911: X5 30d M-Sport:Artic Grey:Comfort Pack:Tech Pack:Visibility Pack: Driver Assist Pro Pack:Heat Pack:Glass Roof:Leather Dash
05-29-2013, 11:21 PM | #3 |
Rep 343
05-30-2013, 04:31 AM | #5 |
Owner
132
Rep 566
Interesting, that CDV story. That might explain some of the behaviour when shifting quickly -- typically in sport mode, there is a 'jerkiness' when accelerating quickly and changing the gears as fast as I can...
However I can't find a trace of the CDV for the F25 -- perhaps it's been integrated into another component, and is no longer 'fixable'? BTW I'm getting a /bit/ better with the clutch, but after 6500 miles, I find it still very very hard to make a true, clean and smooth getaway.
05-31-2013, 09:16 AM | #6 |
Yorkshireman trapped in a Berkshire postcode
12
Rep 213
Item 11 on the diagram below. I did mine on the 130i with some friends. One of them simply punched the middle out then re-fitted it. Transformed the car and made it much easier to drive.
http://realoem.com/bmw/showparts.do?...50&hg=21&fg=10
X3 3.0d M-Sport
Mini Countryman Cooper S ALL4 |
06-02-2013, 12:00 PM | #7 |
Owner
132
Rep 566
Hmm needs to be pretty brave without a replacement valve on hand!
Thanks for the link tho, very interesting...
06-03-2013, 05:11 AM | #8 |
12
Rep 213
The valve was cheap so I got one anyway - top pic shows the bits which come out when you hit it. I think it was a 10mm Allen Key
X3 3.0d M-Sport
