04-12-2011, 06:01 PM | #1 |
Rep 50
Run Flat Tire Repair
I have a nail in one of mine, the idrive displayed a warning but the tire appears to be fine with no visible loss off pressure. Can the nail be pull and the tire repaired? It would suck to have to replace a tire with only 1000km on it.
Thanks "Goodyear Eagle LS-2" Last edited by Spitfire; 04-12-2011 at 06:09 PM.. |
04-12-2011, 07:18 PM | #2 |
Rep 211
As long as it's in the tread and not the sidewall it can be plugged and will last the life of the tread. Even though my E83 has a spare, I carry a compressor and a plug kit. I will only mount the spare if I can't plug it.
If you decide to buy a kit and plug it yourself I suggest using cement on the plug even though they say it's not required. I've plugged more tires this way than I can count and I've never had a problem. |
04-12-2011, 07:31 PM | #3 |
Rep 12,276
IMPORTANT!!! Please do not go by how the tire "looks". The stiff sidewalls of the RFTs will keep the tire up and is no a good indication of pressure. Put a gauge on it right away before driving. If you have lost all pressure, then you have likely damaged the integrity of the sidewall and a plug repair is questionable. If you still have decent pressure, then get thee to a pump and fill it - then directly to the tire shop.
FWIW, I have two BMW's with RFTs and I keep a tire repair kit in each vehicle. 12v compressor and plug kit. Lesson learned from having a flat in the middle of nowhere....
I think it is bad luck to be superstitious |
04-12-2011, 07:40 PM | #4 |
Rep 1,876
Tire and wheel insurance handy in this situation. Don't have to assess, just get a new tire at no additional cost.
04-12-2011, 07:44 PM | #5 | |
Rep 12,276
I won't try to start an argument over wheel/tire insurance, but like any insurance it is a cost/benifit analysis that we each have to make for ourselves. Of course, when we need a tire or wheel, we ALL wish we had it.
04-12-2011, 07:49 PM | #6 | |
Rep 1,876
