      06-06-2012, 06:42 AM   #1
merdemir
Drives: BMW X3 F25
F25 2.0d operating temperature
Hi, my x3 is always running at 100 celcius. Do you think is it normal? İ couldn t find any information on that subject. And also it should be oil temperature not water, is it right?
Regards.
      06-06-2012, 06:57 AM   #2
ninoo
Drives: 2015 x3 2.0d Auto
yes, my 2.0d always settles at 100 . 10k miles covered
      06-06-2012, 07:06 AM   #3
merdemir
Drives: BMW X3 F25
Thank you. It is nice to hear it was normal.
      06-06-2012, 07:13 AM   #4
tank531
Deckhand
tank531's Avatar
Drives: F25 2.0D SE xDrive (Sep 11)
100 C is normal. It can operate at this temperature as the system is presurized.
      06-06-2012, 07:31 AM   #5
greierasul
electrical engineer
Romania
Drives: X3 - 2.0 L diesel- 184 CP
100 celsius degrees ? Maybe I am a old fashion guy, but for me sound too much. Maybe the indicator it is not good calibrated. If that temperature it is for a short period of times, everything is ok.
      06-06-2012, 08:23 AM   #6
plymjack
Nuclear Chief of the Watch
plymjack's Avatar
Drives: X3 (F25) 2.0D, i3 BEV
100 C is fine mine is always there... after its warmed up..
BMW X3 (F25) xDrive20d SE 2017. . . . Oyster Leather . . 8 Speed Servotronic. .RFTs. . Electric Seats
Canon 70D 500mm, 85mm, 40mm, 24mm
Sony QX10 & GoPro Hero 3
      06-06-2012, 08:32 AM   #7
merdemir
Drives: BMW X3 F25
Yes it is always 100 C after heated İ think it is oil temperature not coolant. Otherwise can be dangerous. Can boil water.
      06-06-2012, 11:18 AM   #8
Jan van Zyl
Namibia
11
Drives: 2011 X3 (F25) x-drive 2.0D
Regards.
Definitely oil temperature - so when it reaches "working" temperature engine is ready for optimum performance and economy. Coolant temperature reaches working levels much sooner - but no such gauge on F25. Oil takes quite a bit longer - probably even more so on diesels - which are slightly cooler running. Could also explain the potential for DPF problems - if so equipped - when mostly short trips are done.
      06-06-2012, 03:42 PM   #9
merdemir
Drives: BMW X3 F25
can you explain more dpf problems? what does it mean? because i must do short trips always.
      06-07-2012, 01:49 AM   #10
Jan van Zyl
Namibia
11
DPF = diesel particulate filter - to catch up soot. It's a country specific addition - countries with ultra low sulfur diesel - the F25 here will most likely have it. Dealer will be able to tell whether your vehicle has it or not. If fitted - most likely will be incorporated with the normal catalytic converter - so may be difficult to ascertain on your own whether fitted or not. Southern African vehicles not fitted (except X5 40D) - but may change some time in future when ULSD much more freely available. Hope this helps.
