04-09-2021, 04:47 PM | #1 |
Rep 18
X4M40i f26 Mods & Pics
Hi all, getting close to finishing mods so thought would share mods and pics. Still to do exhaust and CF diffuser and maybe ECU and aFe intake and Bimmercode
Outside mods CF side markers CF rear reflectors CF roundels all around Black out chrome around rear roundel CF M license frames CF fin cover CF front kidney grills CF mirror covers CF wrapped front titanium color eyebrows H&R lowering springs Body color mud flaps Front & rear spacers AC Schnitzer Type V 20” rims Front hood and bumper 3M bra 3D Design CF splitter 3D Design rear spoiler Inside mods CF open pore trim and shift knob LED M door projector lights 3D Design pedals CF steering wheel roundel Tinted windows CF open pore steering wheel cover Paddleshifterz LED interior lights M Performance mats |
04-16-2021, 11:08 AM | #4 | |
Rep 37
If you don't mind sharing specs on spacers front and back please. Also, how is the ride with the H&R springs? |
04-16-2021, 06:23 PM | #5 |
Rep 18
Thanks.
Well I am using 10mm back and 3 mm front. But that is specific for the ACS rims (fronts are 20x9 with 22 offset and rears are 20x10 with a 33 offset). I have winter rubber on the OEM stock X4M 40i rims which are 20x8 front with 38 offset and rears are 20x10 with a 51 offset. So to bring the OEM rims out to the same point as the ACS rims, I use 20 mm spacers front and back. If you are using other than OEM rims then you need to know the offset of front and back and then do the math to determine size of spacers needed. Ride with the H&R springs is about the same. H&R makes the springs that come in the stock X4M 40i so not much diff. Only diff is “looks” as the H&R springs drop the vehicle about 1”. |
04-19-2021, 03:40 PM | #6 | |
Rep 37
Lastly where did you get the front 3D front lip and how was the fitment? |
04-21-2021, 09:41 AM | #7 |
Rep 18
Welcome.
Fitment for the front splitter was excellent 100%. Spoiler was about 90% as had a small gap at one end (underneath the spoiler so not visible). I purchased from the Canadian 3D Design dealer (MW Design Technik). If go to the 3DDesign website (Japan) they list the dealers across the world. |
04-21-2021, 09:50 PM | #9 | |
Rep 16
04-22-2021, 05:39 PM | #10 |
Rep 18
Thanks. Mudflaps were from Amazon (3 years ago) but listing not there now. Found similar ones on eBay. See pics. Re suspension, was done 3 years ago as well. Not sure how much time to settle. But checked actual space and rear still sits about an inch higher. Pics don’t seem to show that but rear does sit higher. |
IAMPRATTE28.00 |
05-02-2021, 08:47 PM | #11 |
Rep 157
Drives: M4; X4 M40i
Ultima,
Do you still like the ride with the H&R Springs? Where did you get the springs? Thanks |
05-03-2021, 05:28 PM | #12 |
Rep 3
Wow stunning car. That mod list is exactly as it supposed to be. Just got my hands on a F26 X4 but parts are scarce in my part the world so will need to import almost everything.
05-03-2021, 07:50 PM | #14 |
Rep 18
Thanks. Still trying to decide if go with Stoner exhaust, 3D Design or Supersprint.
Hope you enjoy the new ride. Sounds like will take some time to do mods—but that’s the great thing, will always want to do something and will be a long term project. |
06-20-2021, 07:53 PM | #17 |
Rep 18
I actuallly wrapped them in carbon fiber vinyl. I’m sure can paint if dull the surface with a 600 sandpaper.
They are easy to remove. The front of the marker has a fixed clip. The rear of the marker has a spring loaded clip. So all you do is push from the front of the marker towards the back of the car. The spring will “give” and then remove from the front of the marker |
06-20-2021, 07:55 PM | #18 |
Rep 18
Seems pic didn’t come thru??
06-20-2021, 11:18 PM | #19 |
Rep 4
It looks really beautiful in carbon. I thought it was black but in this color it just looks great. Thank you for the detailed explanation. So you think it's more efficient to wrap in foil instead of do you paint?
Aleksandar
06-21-2021, 07:26 PM | #20 |
Rep 18
Welcome. Well I just like Carbon Fibre. So anything that I couldn’t get real CF, I wrapped with CF vinyl. Can buy on Amazon. But also need a heat gun. Had to paint rear BMW trunk emblem as wrapping didn’t last. But as I said, need to sand and take off sheen for paint to stick. Have not had any issues with the CF wrapped side marker.
07-31-2021, 03:26 PM | #21 |
Rep 18
Just had following installed
VRSF high flow catted downpipe VRSF charge pipe aFe intake. Then had ECU prgmed with Stage ll bootmod 3 Sounds great, a rocketship —hp 470, tq 460 (per bmd3). Will have it dynoed to see. Last thing is 3D design exhaust and CF diffuser. |
Bhandyman19764.50 |
