      06-27-2011, 06:52 AM   #1
guycashmore
Drives: 2011 X3 3.0D SE
Yokohama A/T-S 'all terrain' tyres on 3.0D
I've a new 3.0D being delivered in a couple of weeks
The car is mostly going to be used for towing and needs to be able to get heavy trailers in and out of fields and cope with unsurfaced roads etc.
My current plan is to replace the tyres on delivery with a set of 4 Yokohama all terrains that can be seen here:
http://www.tyretraders.com/tyreInfor...1799HG012.html
I was just wondering if anyone else on here had tried a new X3 on anything more aggressive than the factory fit tyres?
      06-27-2011, 07:17 AM   #2
Bimar
Bimar's Avatar
800
Drives: Bmw X
am curious on the same.
      06-27-2011, 09:22 AM   #3
X5plug-in
What factory fit tyres are people getting? Obviously varies per country but what is on delivered cars so far?
      06-27-2011, 02:02 PM   #4
Radioactive
Drives: '11 X3 28i '10 535i '04 325i
This tire(tyre) will reduce the amount of rubber on the road by about 20% and your ground clearance by about a 1/2 inch. If your going in rough conditions you might want to think about a bigger tire.
      06-28-2011, 01:48 AM   #5
Bimar
Bimar's Avatar
800
Drives: Bmw X
true, unfortunately to get all terrain bmw tires usually don't fit bmw standard spec tyre size so u either get bigger or smaller tires.. which affects a number of things.
      06-28-2011, 08:46 AM   #6
guycashmore
The factory fit tyres my car is coming with are 225/60/17 and the Yokahama's are exactly the same size, so no change here.
Ground clearance is not an issue, no plans to go 'off roading'!
On tarmac handling is not really an issue either, my driving style is 'relaxed' (also called grandad!)
I'm mostly worried about noise from these tyres...
      06-28-2011, 09:00 AM   #7
Radioactive
Bad assumption on my part. I assumed that your tyres were the same size as ours on this side of the pond. 245/55/17.
A smooth ride and noise level will probably suffer a bit, but it's better than getting stuck in a field!
      06-28-2011, 11:35 PM   #8
torzeck
torzeck's Avatar
54
Drives: 2011 X3 35i, 2020 X3 30i
Are they runflats?
      06-29-2011, 03:32 AM   #9
guycashmore
Originally Posted by torzeck View Post
Are they runflats?
No they aren't...
Not having a spare wheel is the one thing I really don't like about the car...
I'm planning to buy a spare rim and get one of the displaced factory tyres fitted to it, then make up a mounting bracket and fit it on my trailer.
      06-29-2011, 02:36 PM   #10
jt2
Annoyance
Drives: Yes
That looks like a pretty aggressive tread pattern. I'd be concerned about road noise.
Just out of curiosity, how heavy a trailer are you planning on towing?
      07-01-2011, 04:21 AM   #11
guycashmore
Typically about 2,000 KG which is about 4,400 pounds I think.
The UK specification 3.0D cars are rated to tow a maximum of 2,400 KG (5,300 pounds)
I'm concerned about road noise too, which is why I was asking if anyone had tried different tyres on these vehicles?
      07-02-2011, 05:48 PM   #12
brissim
Drives: X3 30d (2011 F25) - now sold
guycashmore,
Interesting you should choose Yokohamas. We have a 30d on order for a late August/early September delivery which - for the Australian market - come standard with runflats (Dunlops I believe). With the amount of country driving I do I don't accept the use of runflats and intend to replace the runflats with conventional tyres on delivery.
After a far amount of research on sites such as 'tirerack' in the US and 'carbonblack' here in Australia, I have settled on Yokohama H/T-S (Geo G51) as a replacement tyre. Not as an aggressive pattern as the A/T-S, but should do the job.
Tony
      07-05-2011, 04:34 AM   #13
guycashmore
Originally Posted by brissim View Post
guycashmore,
Tony
Thanks for your input here, I also looked at the H/T-S but decided it wasn't agressive enough, I live in the far south west UK and it tends to be mostly 'wet and muddy'.
Runflats are a cost + option in the UK.
My car is being delivered in about 2 weeks time, the Yokohamas have arrived already and look to be a very well made tyre, I'll post as soon I've had chance to try them!
      09-07-2011, 08:34 AM   #14
mummyedweeds
Drives: X3 3.0i E83
Any luck with the Yokohama's?
