08-18-2015, 03:37 PM | #1 |
Rep 2,808
What's the longest roof cargo box you've put on?
Currently I have a Thule Atlantis 1200 box, which is 82 inches long and 24 inches wide. I had purchased this one at the time because I could still fit three bikes up top with it. But now with the new X3, one thing I'm finding out (which I knew right off the bat I'd miss) is that with the increased height of the car, I can no longer leave a roof box on there all the time and go into underground garages, most of which have an 80 inch limit.
I had measured the 535, and the car was perfect at a height of 59 inches, plus 20 inches for the roof box and feet. The X3 though is 65 inches high. Since I'm toying with dropping it an inch using springs, I think I actually might be able to pull it off, (to get under 80 inches), if I go with a thinner box, which would be 11.5 inches high. The Thule "thin" boxes though are 24" wide, so I'll go with a Yakima. Here's my question: The Yakimas are 92" long. That's a full 10" longer than my existing box, which lines up with the top of the windshield. If I get a longer box, it will look sort of like the second picture, with the edge of the box in line with the mirrors almost. I still wouldn't see the box though sitting in the driver's seat, I moved up my own box to check it out. Are there any negative considerations for getting a long box that overhangs the windshield, besides looking ugly? Wind noise? Much worse mileage than my existing box, which matches the roof outline? Thanks! PS I found the mockup at MR-BOX.com Last edited by Lotus99; 12-10-2015 at 12:25 PM.. |
08-19-2015, 12:50 AM | #2 |
Rep 1,259
You will get slightly worse mileage. Should not get more windnoise. Rear door will probably interfear with box - you have to electronically reduce opening angel.
Lowering 1" - 1 1/2" (and not exchange/shorten shocks) will mean you will slightly ride on bumpstops= reduced ridecomfort- especially fully laden. |
08-19-2015, 12:59 AM | #3 |
Rep 2,808
Thanks for the input. The picture of my car is skewed, in that the rear of the box actually lines up almost with the rear door seal. When the hatch is up, there's an inch of space between it and the box. So if I buy the new longer box, it won't interfere with the hatch opening if I put it where the current one is, unless I move it farther back. It will just stick out of the front more by about 25 cm/10 inches.
Do you think it looks too ugly hanging over the windshield like that? In the mockup picture I found, it doesn't look too disproportionate actually... |
08-19-2015, 10:25 AM | #4 |
Rep 1,259
I think the slender box is nicer - especially if you move 4" backwards
To optimize from an aerodynamic standpoint you should: -move backwards as much as possible - and reduce rear door lift. -lower the box in front, to reduce amount of air passing under box. |
08-19-2015, 11:50 AM | #5 |
Rep 2,527
I have the Thule Sonic L. It sits right in front of the rear hatch (hatch can still open no issues) and it overhangs the front windshield a bit, and I do see it while driving. If I were to do it again, I would have purchased the Alpine version (lower slung) as the Sonic looks like I'm transporting a small whale on top of my X3.
08-19-2015, 01:39 PM | #7 | |
Rep 2,808
Is it the width you don't like about yours or its height? The Sonic Alpine seems really long to me, at 96 x 27.5 x 11", and is only 10 cu ft of space. The Yakima LoPro I'm considering would be a bit shorter than that, but I figured if I'm going to spend lots of $ to get a new box, I might as well maximize the space inside, and get a wider box than the Thule. It fits 15 cu. ft. |
