      11-14-2023, 07:26 AM   #1
HighDeaf
Drives: 2012 bmw x3 f25 3.5 M Sport
X3 nN55 temp sensor not working?
Hasn't worked for over a year, engine seems to run fine, doesn't overheat heating and air-conditioning all seem to work fine, any ideas?
      11-21-2023, 10:14 AM   #2
hardparker
Father of Frankenfold
299
Drives: Yo daddy's 2014 X3 M Sport
2013 BMW X1  [0.00]
2014 BMW X3  [0.00]
Which temp sensor? Oil, coolant, outside air? Throwing any codes?
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
      11-21-2023, 08:36 PM   #3
HighDeaf
Should have been more specific, the Temp gauge in the dash is not functioning. It doesn't move at all. It's not showing any codes.
      11-22-2023, 09:50 AM   #4
Wgosma
Drives: 2012 F25 X3 28i (N52)
You can use the "hidden menu" in the car's onboard computer to see if it's shows live oil and coolant temp readings....if so, then like you have a gauge issue, if no temp data in hidden menu then likely temp sensor is at fault. YouTube search will get you instructions on accessing the hidden menu.
      11-23-2023, 09:23 AM   #5
HighDeaf
Great that's a good lead, I'll check that out today! Thanks.
Wgosma806.00
