      03-16-2017, 05:18 PM   #1
w5xz
Drives: 2011 x-3 28i x-dr, 2012 335i
2011 BMW X3  [0.00]
'charge battery' ???
i DID, but keep getting same junk on dash, on shut down. Even used a better-than-average charger for several hours. 2011 vehicle, so it IS 6 years old.
may try an E-sys fault re-set also.
regards, Dan
      03-16-2017, 05:40 PM   #2
Peter_R
Air Vice Marshall
Peter_R's Avatar
You need a new battery. Six years is a long time.
2012 BMW 320d Sport (F31).
2013 BMW X3 xDrive 30d M Sport (F25).
2020 BMW X1 xDrive 2.0i MSport (F48).
2022 MB EQB 300 4MATIC AMG Line Premium
BMWZ41909.50
      03-17-2017, 08:21 AM   #3
Barbera335
Drives: F25
regards, Dan
Or you could replace your battery as stated above. Same thing happened to my 2011 and a new battery cured it.
      03-24-2017, 08:48 AM   #4
dcaron9999
dcaron9999's Avatar
Drives: 2011 135i M package
Approve of the battery swap recommendation as well. No need to get an overpriced OEM battery either.
You are lucky to have stretched the OEM battery life to 6 years actually. The norm is about 4 years, maybe less depending on your use case (short trips, car unused for extended periods, heavy use of hungry accessories such as heated seats, rear window defogger, etc.)
2011 X3 35i with M pack + 2011 135i w/6SPMT | 255 square tire setup | Quaife 3.46 LSD | Diff lock down bracket | Bilstein B8+Swift SpecR springs+H&R FSB | CDV delete | BMS Oil Tstat bypass | ER FMIC & CP | N54Tuning DP | GC Street Camber Plates | M3 FCA +guide rods+RSFB's+Tranny mounts | Manzo toe arms | Cobb Stg2 agressive tune | Hawk DTC70 brake pads | RB SS brake pistons | Goodridge SS brake lines | Custom brake cooling ducts
      03-27-2017, 03:46 PM   #5
najnad
General of the Space Forces
najnad's Avatar
Drives: 11 X3 35i M-sport
check to make sure your system is charging your battery properly, the infamous oil filter housing gasket has claimed my belt (and possibly alternator) causing the battery not to charge.
      03-28-2017, 03:06 AM   #6
dcaron9999
dcaron9999's Avatar
The 2011 X3 35i I bought 2 weeks ago, is loaded with options, and has displayed charging issues, which have cleared, after one stop and start cycle. I ahve used battery chargers on and off during the last week, but my X3 seem not to like the obsolete charger Im using.
The load issues were mostly caused by my learning process of the car, ie: not being careful while exploring accessories , exploring Idrive options, NAV map update, while the engine was off.
After a bit of poking around, in the forums, I may be in the same boat as the OP, that is, my car battery is rapidly approaching the end of the road. I assume it is the original unit that came with the car, but I cant say. Maybe a tool like INPA might reveal its age...
Wish I could tell how old the battery is for sure. The PPI (Pre-Purchase Inspection) and maintenance records at the dealership did not reveal anything wrong with the battery or charging system, or stray electrical devices not going to sleep mode properly...
I went ahead and ordered an AGM specific smart battery charger, and portable compact jump starter to always carry around.
Again, this vehicle has so many options that could potentially drain the battery for devices not going to sleep mode properly or quickly, and very cold weather extremes we get here in Quebec, Canada. After some research, Youtube torture tests, and for my peace of mind, I pulled the trigger on these goodies:
Jump Starter: https://www.amazon.ca/gp/product/B01...?ie=UTF8&psc=1
Smart Battery charger: https://www.amazon.ca/gp/product/B00...?ie=UTF8&psc=1
Next step is purchasing fresh and powerful AGM car battery (aftermarket).
      04-01-2017, 05:41 AM   #7
dcaron9999
dcaron9999's Avatar
Can't say enough good things about the quality of this CTEK MUS 4.3 unit, and its adaptor cables.
I decided to semi-permanently attach the quick disconnect ring terminal cable to my charge poles under the hood (battery is in the trunk).
The cable itself has a rubber protective cap to prevent dirt from reaching the electrical contacts when not in use. Simple, but just well through out and well engineered all around. The charger is small but still delivers 4.3Amps. It has 8 phases of charging, testing, conditioning , and maintaining your battery. Check out the pics and video I shared below.
https://www.youtube.com/watch?v=Wugp7n84TbQ
      04-02-2017, 09:50 AM   #8
plymjack
Nuclear Chief of the Watch
plymjack's Avatar
Drives: X3 (F25) 2.0D, i3 BEV
Our 2012 battery is fine at present but as we only use it now for on longer trips we sometimes dont run it for 10 days or more - we always get a battery warning after 8 days or so we have a Smart Charger which works like magic... and we do seem to be getting good life out of the battery..
BMW X3 (F25) xDrive20d SE 2017. . . . Oyster Leather . . 8 Speed Servotronic. .RFTs. . Electric Seats
Canon 70D 500mm, 85mm, 40mm, 24mm
Sony QX10 & GoPro Hero 3
