      02-20-2017, 12:53 PM   #1
alpwhite46
Drives: 2013 X3 35i Mpkg
Golf Tee Mod - Disconnect Q
Hi Guys,
Just opened up the rear left area of the trunk - can someone help me figure out which one it is for the valves to disconnect?
I have a 35i, maybe someone can circle it in the picture
      02-20-2017, 01:30 PM   #2
alpwhite46
I think it would be this since judging by other photos it has that silver clip:
      02-20-2017, 02:45 PM   #3
alpwhite46
Done - i notice a little bit of a difference.
      03-03-2017, 01:03 PM   #4
Lotus99
Lotus99's Avatar
Drives: 19 M2C & 18 X3 M40i
There is no need to unplug the electrical connector. In fact, if you do, I think it won't do anything IIRC. Did you check afterwards by looking into the exhaust After a cold start up?
It works the opposite way on these cars as it does on the N54 cars, where the electrical connector maintains vacuum typically that keeps the valve shut, so by unplugging it, it opens the flap all the time. Whereas in our cars, the vacuum from the engine comes from the front thru the tubes, and that's what keeps the flap closed. The valve operates with vacuum and the solenoid in the trunk gives it vacuum when needed. So you have to bypass them.
I went off of this old guide and it worked.
      03-03-2017, 10:21 PM   #5
alpwhite46
Hmm weird ... do you notice a difference when you did that?
Where can i get the two-inlet vacuum hose connector?
      03-03-2017, 10:42 PM   #6
scrammer
scrammer's Avatar
Drives: 2017 M3 Ultimate
Lotus99 is correct ... on my N54 335is I simply unplugged the connector in the trunk and both pipes/ports opened up and the sound change was awesome. When i got my new to me 2015 X4 35i, I disconnected the first day and noticed that only one pipe was emitting exhaust .... so after a little research I simply wired the actuator open as per posts 17-19 at the link below:
http://f10.m5post.com/forums/showthread.php?t=814739
To check it out, cold start your ride and reach in behind the rear wheel and manually actuate the linkage by hand (before the pipes heat up) and you will see and hear that both ports will be open and sounding good!
Entire process took 7 minutes ...
Current ///M: 2017 M3 Ultimate
Past ///M Cars: E92 M3 ZCP 'CDN LRP' … E85 Z4M-R ... E92 M3 ZCP Frozen ... E90 M3 ... E46 M3 Cab ... E46 M3 ZCP ... E46 M3
      03-04-2017, 08:48 AM   #7
alpwhite46
Damn anyone from Toronto done this?
      04-07-2017, 08:49 PM   #8
xdriv3
Drives: X3
I will definitely check this out. Thanks!
