      08-13-2011, 10:16 PM   #1
Want the thrill
2022 X4M40i  [10.00]
Are interior bulbs covered?
Under warranty? Went to turn on my front passanger overhead reading light and it came on and instantly burnt out. It's the only light out in the car so I don't think it is a bad fuse. Are these covered under warranty? X only has 840 miles on it.
      08-13-2011, 10:34 PM   #2
Nahoa
Yes.
      08-13-2011, 10:59 PM   #3
Want the thrill
2022 X4M40i  [10.00]
Thanks Nahoa for the quick response!
      08-13-2011, 11:01 PM   #4
Nahoa
I tried to think of something else to say, but that seemed to cover it.
      08-14-2011, 12:42 PM   #5
Want the thrill
2022 X4M40i  [10.00]
So the bulb that went out last night and wouldn't come on is now working today. What's up with that???
      08-14-2011, 12:52 PM   #6
Nahoa
Odd. Does the switch seem to be working properly?
      08-14-2011, 01:01 PM   #7
Want the thrill
2022 X4M40i  [10.00]
Yes, switch seems fine. I turned it off and on a bunch of times messing with it today with no problem and then left it on to see if it flickered at all while I was driving (thinking that the bulb might be loose). Stayed on the entire time without flickering.
      08-14-2011, 01:14 PM   #8
Lotus7
Drives: xxxx
Possible that the bulb was poorly seated and now has settled in. Likely causes in order of approximate probability: Poorly seated bulb, intermittent switch, loose push-on connector, phase of the moon, poltergeist, hallucinations. Take your pick!
      08-14-2011, 01:30 PM   #9
Want the thrill
2022 X4M40i  [10.00]
You got that right! lol
      08-14-2011, 06:26 PM   #10
skier219
Drives: X3 M40i, M2C, Ferrari 328
Could be a flakey filament too. I have seen those before. If it craps out again, that would be my bet.
      08-14-2011, 10:35 PM   #11
sard
Drives: 2008 M3
Speaking of lights coming on and off. I hardly see X3's around here, but today I saw two. One was turning left inside the parking lot and I noticed only one fog light was on. Then both were off. Does the fog light on the inside of the turn, when turning, turn on to help illuminate the road, then turn off?
E92 M3 - DCT - 20" BBS LM-R - KW Clubsport - Akrapovic Exhaust - Powerchip Tune - Arkym Aero Kit - HID Halo
      08-14-2011, 11:51 PM   #12
Want the thrill
2022 X4M40i  [10.00]
Yes, the fog light on the side you are turning towards will light up when making the turn. It goes back off once the turn is completed.
      08-15-2011, 12:57 AM   #13
Lotus7
Drives: xxxx
Only if you have the "Adaptive Light Control" option (included in the Convenience Package). That option also includes brighter 55 w. fog/turning lamps instead of the base level 35 w. lamps.
No ALC, no auto-on fog lamps when turning.
      08-15-2011, 04:28 AM   #14
Broch
Drives: BMW X3 35d M-Sport
Would this be Code 524 which is included in the "ZXG-Visibility package" here in the UK?
      08-15-2011, 05:10 AM   #15
Nahoa
Also turns on when you initiate a "hard" turn signal for a bit, then comes back on when you actually turn. Does it activate on the 3-bob lane change signal?
