      03-20-2015, 05:22 AM   #1
Harshalkpatel
Drives: f30 328i f25 x3 20d
left side pulling problem!
recently i bought x3 2.0 diesel x line in India.
since the first drive car tries to drift way to left side, i feel constant stress on the steering wheel.(RHD VEHICLE)
complained about the same to local dealer,they tried to do alignment for 3 or four times but still the problem persist.
dealer also tried swapping entire set of tyres and alloys with new car( don't know why) but still problem persist .
now they doubt suspensions for the same.
since i have bought new car and i reckon bmw has good "quality checks" standards before they send vehicle to dealership i wonder what is the real reason for the such problem.
has anyone faced similar problem?
      03-20-2015, 09:28 AM   #2
mge92
SPEED RACER
mge92's Avatar
Drives: BMW X5 M50d BMW M2 CS
Could be the tires ...
2019 BMW X5 M50d Artic Grey | 2020 BMW M2 CS Misano Blue
Incoming - Ginetta G56 GT Academy | Incoming - BMW X5M Comp Oxford Green
RIP - 2020 Mini JCW GP Racing Grey | RIP - 2013 X3 xDrive28i Carbon Black
      03-20-2015, 09:38 PM   #3
Want the thrill
2022 X4M40i  [10.00]
A remember reading a post about someone with a similar problem and they said replacing their perch springs and spindles fixed the problem.
      03-21-2015, 06:24 AM   #4
Ryno 27
Drives: M5 Competition, X5 M50i
It's the tires
      03-21-2015, 02:07 PM   #5
Want the thrill
2022 X4M40i  [10.00]
Originally Posted by rynomi6 View Post
It's the tires
He already said he swapped the tires and rims and no change.
      03-21-2015, 04:12 PM   #6
mge92
SPEED RACER
mge92's Avatar
They type / model of the tire. Try changing to a different model of tire.
      03-22-2015, 06:44 AM   #7
Harshalkpatel
car is now at dealership! they are doing some full body diagnose! meanwhile i have mailed bmw India to provide me replacement for this car.
      03-22-2015, 06:57 AM   #8
Portimao318
Portimao318's Avatar
61
Drives: BMW 318i Touring MSport
Is it a brandnew car , or not ? Could it be that it was involved in an accident ?
2022 318i Touring MSport Portimao blue
      03-22-2015, 12:06 PM   #9
Harshalkpatel
Yes its a brandnew car!
      03-22-2015, 09:53 PM   #10
02420X3
Drives: 2011 X3 35i
Note that X3s which are sold in India are assembled in Chennai, India from CKD Kits which are manufactured in the US. IMHO, Harshalkpatel is doing the exact correct thing by raising his problem with BMW India. His dealer is still attempting to correct the problem, but there is no obvious solution. Involving BMW India is not a bad idea.
      03-23-2015, 12:30 AM   #11
Harshalkpatel
yes have to involve BMW India, x3 in India is for 90K USD.
leaving price apart i don't expect BMW to provide such defective car,the way car drives rightnow is against their tag line "sheer driving pleasure".
expecting reply from Bmw India today.
      03-23-2015, 12:44 AM   #12
Harshalkpatel
dealer has tried to re program" suspension module as it has electronic damper setup.
lets see what they do next
      03-23-2015, 05:01 PM   #13
akshay1234
akshay1234's Avatar
India
30
Drives: E90 320D, F25 X3 30D
2011 BMW 320D  [0.00]
Harshal do let me know how it goes. I have been facing a similar issue on mine. You have to put a slight bit of pressure to keep the steering straight, and if you leave it it immediately tilts a bit to the left. But when you hold the steering straight the car doesn't drift to the left. So I imagine the alignment is fine. The dealer had swapped the left and right front tyres, which made it a bit better, but its not become worse again.
Im very interested in knowing what happens next, and will possibly speak to BMW India for the same solution if they find you one.
      04-18-2015, 12:02 AM   #14
Harshalkpatel
hello! akshay!
finally problem solved. dealership replaced 'Steering Assembly' and 'Steering Column' since then the car is neutral now.
we also had to replace front two tires as they were worn out unevenly due to left side pulling.
all the best with your X3
      04-18-2015, 12:52 AM   #15
akshay1234
akshay1234's Avatar
India
30
Originally Posted by Harshalkpatel View Post
hello! akshay!
How many kms done on your car?
Also whom did you speak to at BMW India?
I'm now going to pursue it.
Tags
alignment, f25 x3 facelift, instant drift to left
