06-07-2012, 09:19 PM | #1 |
Captain Amazing
Rep 104
Freshly coded 2013 X3 28i (US)
Hi all- just letting you know I just successfully coded the following using a home made cable and esys:
•Mirror fold on lock/unlock •Windows up down via fob and CA •Trunk close via fob/inside button •iDrive disclaimer delete •Auto Start/Stop off by default • Doors auto unlock at ignition off **trunk feature did take a while to activate--- give it a good 15 minutes, leave the car off- walk away ** The cheat sheet from the F10 coding sticky was used (another site). Very helpful. Thanks to all who have helped me!!! Here are the videos! Playlist of 5 vids: http://www.youtube.com/playlist?list=PLA0F086771F8695F2
2013 X3 28i DSB/Mojave/FW
SA, CONV, CW I, PREM, PREM SND, TECH, HUD Last edited by StepfordBMW; 06-09-2012 at 10:52 AM.. |
06-07-2012, 10:15 PM | #3 | |
Love All
170
Rep 740
Now you should help others who want to try the same. I have ordered a bare connector, I will wire it and then try it. LET PEOPLE KNOW THE RISKS INVOLVED AND IT'S NOT EVERY ONES CUP OF TEA UNTIL ENOUGH DATA AND EXPERIENCE IS GENERATED. |
06-07-2012, 10:40 PM | #4 |
*Bimmerpost Plasti Dip Guru*
81
Rep 1,174
Drives: E53, E46-M3, E70, F25-X3
Can you make a video of it :O
06-08-2012, 08:07 AM | #5 |
Captain Amazing
Rep 104
Oh there are definite risks - you could totally muck up your total car by selecting wrong values in a wrong module. USE CAUTION people! Go slow, take your time. Code one thing at a time and test it before proceeding.
SA, CONV, CW I, PREM, PREM SND, TECH, HUD |
06-08-2012, 08:27 AM | #6 |
Rep 157
It is fairly straightforward, but as pointed out there are risks. Also doesn't help that a lot of the ESYS content is in German!
But as long as you have one of the guides that are floating around you wont go wrong and the feeling of permanently disabling Start/Stop is very satisfying. |
06-08-2012, 08:37 AM | #7 |
Rep 11,843
Drives: MY24 G01 AW Msport
i think before making any coding any changes do a BACK UP of the stock settings
06-08-2012, 10:30 AM | #8 |
Love All
170
Rep 740
06-08-2012, 10:36 AM | #9 | |
Rep 343
Is there a setting to reduce the sensitivity of the auto headlights? A setting to turn off the 5min seat belt chime? |
06-08-2012, 10:43 AM | #10 |
Rep 157
06-08-2012, 10:53 AM | #12 |
Captain Amazing
Rep 104
Not 100% positive on the headlights - they do seem very sensitive - even in a 100ft tunnel they go on at 70mph!
As for the seatbelt chime - yes! I'll PM you the info as I don't think I can post it here.
06-08-2012, 10:59 AM | #14 | |
Rep 157
http://www.bimmerfest.com/forums/sho...d.php?t=619819 |
06-08-2012, 12:31 PM | #15 |
Love All
170
Rep 740
06-08-2012, 12:34 PM | #16 |
Captain Amazing
Rep 104
posting
I just couldn't post it in quick reply- but I don't think the moderators/rules allow posting and including other forum names/addressed.
06-08-2012, 12:36 PM | #17 |
Love All
170
Rep 740
06-09-2012, 02:36 PM | #19 |
Love All
170
Rep 740
Well done StepfordBMW!
I prepared my obd 2 connector and ready to jump into other software installation. Need one clarification on esys installation. Step 4 of the procedure says copy est folder to C:\ESysData\e-sys est Is it C:\ESysData\e-sys\est ? Please clarify. Thanks. |
06-09-2012, 02:46 PM | #20 |
Captain Amazing
Rep 104
Yes- just copy the folder as a whole - (If I recall correctly)
06-09-2012, 02:51 PM | #21 | |
Rep 157
Then copy the contents of the "C:\ESysData\psdzdata\swe" folder into the "C:\ESysData\SWE" folder. Once this is done E-sys should bring up the applicable models when you connect. EDIT: that's not what you're asking but it might come in useful for the installation. |
06-09-2012, 02:54 PM | #22 |
Captain Amazing
Rep 104
Thanks gareth--- I'm not at my pc currently otherwise I'd love to help
Guys--- use the F10 coding forum on b***erfest, it's where I got all of my information. The guys there are pros practically.
