      05-25-2016, 10:41 AM   #1
aris21
aris21's Avatar
36
Drives: 2011 M3 E92
Mysterious shuddering/vibration
Mysterious shuddering/vibration on a 2004 x3 with 130k miles awd.
Hi everyone, my x3 is shuddering under any acceleration. You could cruise 65 mph with no vibration at all but once you put gas on it the car violently shakes. It does it even at 5 mph. Both my shop and I are at a lost. Since this started I've replaced the ff:
-new shocks front and rear
-new wishbone and control arm bushings
-new motor mounts
-wheels are newly balanced and aligned
My shop basically checked off guibo (flex disc) and driveshaft saying that they're perfectly fine..
I'm at a lost ran out of ideas. Any thoughts on this?
      08-30-2016, 01:55 AM   #2
RimasRS
RimasRS's Avatar
85
Drives: BMW X3 SD
Maybe also worn front or rear CV joints
      10-23-2016, 07:21 PM   #3
slione
Drives: 2005 X3 2.5i
If a car shakes only when accelerating it is usually a bent axle. Are you sure that is not the problem? I had a similar issue on a Volvo XC 70. Both left and right front axles were bent.
