      02-06-2013, 08:45 AM   #1
Cycleram
Drives: 2004 X3
2004 BMW X3  [0.00]
Oil leaks
I did my first oil change, reset the service interval display, changed out a burnt out brake light bulb, and headlamp unit. Now on to the next project, finding and stopping an oil leak. I thought I would start with the valve cover, and move on from there. Any suggestions on typical sources?
      02-08-2013, 02:21 PM   #2
kq328xi
kq328xi's Avatar
Drives: BSM e92 328xi, Flamenco Red X3
2008 e92 328xi  [0.00]
Check the sides of the engine to determine where the leaks may be coming from. I had the pleasure of doing this in my wife's X3.
If oil residue is visible on the engine block facing the passenger side, you have a valve cover gasket leak. I replaced the VCG two years ago because of a small leak.
If oil residue is visible on the side facing the driver, you could have a leaking oil filter housing gasket (OFHG) or CCV. I cleaned the engine block thoroughly and watched for oil residue to determine where the leak was coming from. After some spirited driving, it was clear the OFHG was leaking. I had this changed at the dealer because I didn't have time to do and I got a X1 loaner
good luck
2008 328xi e92/Black Sapphire Metallic/Saddle Brown/18" 220M Reps w 225/255 Falken 452's
Next: Sways and springs
