05-31-2012, 05:44 PM | #1 |
Rep 21
iPhone Integration cost?
My wife and I purchased our 2013 X3 28i and took delivery last week. What is the cost to fully integrate the iPhone 4? We purchased the BMW apps and navigation system which includes the BMW assist with enhanced bluetooth and USB. We also purchased the smartphone cradle. We were charged $850 for just the cradle and the iPhone plug..... does this sound correct?
05-31-2012, 05:53 PM | #2 | |
Rep 77
The cradle retails for $250. You can then either use the cradle or a regular white Apple cable (you should already have this since this is how you charge your phone) to connect to the center console's USB port. The cradle provides some minor advantages (better phone reception, ...). The cradle just snaps in so you don't need to pay them to install it. You don't need the Y cable that connects to both the aux and USB ports. |
05-31-2012, 06:12 PM | #4 | |
Rep 77
Here's what you need. See iPhone Snap in Adapter. http://www.bmwusa.com/Standard/Conte...cessories.aspx |
05-31-2012, 06:58 PM | #5 | |
Rep 253
Should BMW have included it as a standard item in all X3s (still leaving it up to you to buy the adapter)? Undoubtedly. Worth it for the marginal gains in features/functionality? Not really. Did I buy it and would I do it again? Yes and probably, because relative to the cost of the car it isn't that bad and I'd hate to NOT have it in case some really cool feature comes out that has the cradle as a prerequisite. |
05-31-2012, 09:25 PM | #6 |
Rep 21
Thanks for the post. I didn't know it cost $850 but perhaps with the upcoming technology it will be worth it in the end. Especially because we are planning on keeping this car for a while. Thanks again for the informative post.
05-31-2012, 09:53 PM | #7 | |
Rep 983
Paying that much for the options is one thing, but for the cradle and a cord? Did you misspeak, or did the Parts Dept. really charge you $850 for a cradle and a cord? |
05-31-2012, 10:03 PM | #8 | |
Rep 77
Either way, I'd go ask them why they charged you $850. |
06-01-2012, 02:07 AM | #9 |
Rep 323
Does anyone know what the specific difference is between using the cradle and the standard USB cable? Does the cradle "use up" - or otherwise plug in to the USB port?
I was thinking of using a normal iPod (80GB Classic) in the USB, and connecting my phone via Bluetooth. Is there any advantage to getting the cradle on top of what I'm already thinking of doing? |
06-01-2012, 02:44 AM | #10 | |
Rep 777
06-01-2012, 07:07 AM | #11 |
Rep 39
The way I understand it is, as mentioned above, the cradle enables you to better secure the iPhone AND allows better phone reception by using the built in antennae in the car.
However, the reason I didn't get this feature is what I foresee in the near future. I now have an iPhone 4. Pretty soon, I suspect an iPhone 5 will be coming out and of course, this phone will be physically different and therefore, no longer fit in the cradle, rendering this feature useless. |
06-01-2012, 01:56 PM | #13 | |
Rep 21
I too am concerned about the new iPhone 5 coming out and whether or not it will fit in the cradle. And word has it the iPhone 5 will have a different power connector. That means a new cord and perhaps cradle. sheeeeeesh! |
06-01-2012, 02:17 PM | #14 |
Rep 323
Interesting, thanks for the info.
So any of you who do have the cradle, can you have an iPod plugged into USB and the phone in the cradle at the same time? |
06-01-2012, 07:57 PM | #15 |
Rep 77
06-01-2012, 09:03 PM | #16 |
Rep 983
Sadly, they are both wrong.
I just stepped outside and tried it, or at least a reasonable facsimile. I used an old iPhone 3GS on the white USB cable, and an iPhone 4S on a cable connected to the dock. The 3GS played with no issues. The 4S played with no issues. When I had the 3GS playing on the USB port and activated the Plugin for the 4S then the 4S took over and the 3GS cut out. |
06-01-2012, 11:04 PM | #17 | |
Rep 323
06-02-2012, 06:23 AM | #18 |
Rep 1,876
Yes, almost always. I keep an iPod Touch plugged in the USB port in the armrest as my main music source and put my iPhone in the cradle most times while driving. The iPod Touch syncs with iTunes when the car is in the garage to update music and podcasts. Very handy.
06-03-2012, 03:23 AM | #19 |
Rep 33
Bluetooth / USB / iOS Version/ cradle issues
Thanks guys...using a second source is a great idea. I just got my new 3.0D MSport on Friday (awesome BTW) I have pro nav (ZXF)' mobile application prep (6NR), telephone USB audio interface (6NF) And a snap-in media adapter (top one with the cooling fan) for my iPhone 4
I had test driven a similar specced demonstrator last year (around Sept) and could stream audio, track info and album art over Bluetooth (no snap in adapter) My car's build date was right at the end of MY2012 production. Early April. I couldn't get music over Bluetooth at all, eventually discovering that I needed to update the Bluetooth software on my brand new car to work better with iOS5. This was a simple download and update, now working much better. But 2 annoying things: 1 can't hot swap between USB audio ( via the snap in adapter) and Bluetooth audio. Need to reconfigure the settings each time. I'm thinking that for many short journeys I'll just keep the phone in my pocket. So I want to stream music using Bluetooth. For longer journeys I want to keep it charged and get the (alleged - because the iPhone has no aerial connector) improved reception. 2 even with the update and Bluetooth configured for audio, can't get album art over the connection anymore ( could last year pre iOS5). Music and track info both fine. Can if I use USB via the cradle config. So I' with you Nahoa- I think an iPod touch on the USB socket under the cradle with "sync over wifi" enabled will work in the garage and give me full audio and I can use my cradle for telephone functionality only.....or possibly video if I ever want to use it...suspect not. Is this how you came to do this?
X3 F25 3.0D MSport - Carbon Black, Black Nevada, Professional Media, 6NR, DAB, variable dampers, folding mirrors, heated front seats, extended storage. Delivered 1st June 2012
06-18-2012, 07:12 PM | #20 |
Rep 21
I finally asked our BMW SA about the $850 charge for our iPhone adapter. He was very apologetic and reimbursed me $850. Once again, we optioned in the Navigation system which comes with the enhanced bluetooth and USB. We also purchased the BMW apps. Evidently this is all that needs to be ordered to get full iPhone integration. I'm glad I asked our SA!!! Hope this helps others in future purchases.
