04-24-2019, 01:04 PM | #1 |
Rep 1,539
'13 35i X3 - Canadian - TPMS Q?
Hi,
1. From my reading, there's no TPMS on the canadian F25, they use abs sensor. In fact, the stem on the OEM wheels are in rubber. (picture last post here : https://www.xbimmers.com/forums/show...highlight=tpms ) 2. I got new X5 wheels on the X3, no TPMS nor MPSS. Rear size is 275-40-19 , front 245-45-19. Equal diameter. 3. Got the warning pressure code , 80km/h max . 4. I have no flat tire. ABS is working. What could it be ? |
04-24-2019, 03:05 PM | #3 |
Rep 1,539
04-24-2019, 03:30 PM | #4 | |
Rep 15
It's definitely the size difference. The Flat Tire Monitor (FTM) is not a true TPMS. Per the manual:
oVeRdOsE.2716.00 |
04-29-2019, 08:39 AM | #7 | |
Rep 1,539
Pressure variation shouldn't throw a code since I dont have tmps. Unless I have a flat and the rotation variation is enough. Also, on my winter setup I have 1% difference of tire outside diameter front/rear, and this is NOT enough to get a code. (i re-use almost new hakka 8 on my old rwd car) Strange enough since when I put the winter tires, I had no code, and putting back the same summer's I got a code. Anyway, I very like this ABS setup instead of a real tpms, since there's way less chance to fail. Also Im the type of person who check tire pressure every month, so no issue here. |
