      06-08-2015, 08:29 AM   #1
zalagan
Drives: 2015 X3 2.0D Xline
Anyone using EcoPro Analyzer on Android
Can't get this app to work from Android 5 Lollipop - others from BMW work in my 2015 X3 as does the Analyzer iOS app from an iPhone. Suspect a permission problem in Android but wondered if anyone was else was having problems? BMW refuse to acknowledge a fault
EcoPro Analyser provides graphical indication of how economically you're driving and gamification - you can complete with other BMW profiles (spouse) to see who uses least fuel ! Great app when it works
      06-09-2015, 06:57 PM   #2
Rich4
Drives: F25 30d SE
Same here, 5.02 Lollipop but just can’t activate it. Other parts such as fuel level, mileage, range shows OK. Not sure if it’s me or the App but searching Google it seems Analyser has been causing problems for quite a while so probably not related to the new Android updates. Am about to write it off as a gimmick and not waste more time.
Current: X3 30d Auto MY2016
Previous: X3 20d Auto MY2013
      06-10-2015, 03:04 AM   #3
zalagan
Ok thanks Rich - exactly the same issue for me. It did work on my previous 2014 X3 about a year ago but now seems broken from my Galaxy S4. I'll raise again with BMW to see if a fix is being worked on
Thanks
      06-10-2015, 05:08 AM   #4
Peter_R
Air Vice Marshall
Peter_R's Avatar
zalagan & Rich4
Same here. When I saw the posts this morning I connected up my Galaxy S5 (updated Lollipop) using USB connection and the phone says it is connected, but goes no further. I then drove to Oxford BMW for minor work and left it there. When the phone was disconnected it shows the rest of the information correctly giving last connection time and the correct mileage and fuel left.
By the way, the Last Mile app works perfectly. Perhaps slightly better than I expected, because I disconnected phone and put it into my pocket and the service guy then drove it down the road (400 yards) and into the rear of the garage where it is still sitting. It even shows the last 400 yards and the fact that it is still in the rear of the garage. I am 7 miles away at home.
2012 BMW 320d Sport (F31).
2013 BMW X3 xDrive 30d M Sport (F25).
2020 BMW X1 xDrive 2.0i MSport (F48).
2022 MB EQB 300 4MATIC AMG Line Premium
      06-10-2015, 01:38 PM   #5
Rich4
Drives: F25 30d SE
Originally Posted by Peter_R View Post
zalagan & Rich4
Same here.
There is a manual available for download of’ BMW Connected Supplementary Owner’s Handbook’ which comprehensively covers detailed instructions and usage for this App. However, even following that I have been unable to get Analyser to function. Interestingly enough, the manual is dated 2013 and before Android’ s splurge of updates starting last year from version 4.4.1, so it’s quite possible that the App itself needs updating by BMW to cope with the newer Android versions. http://www.bmw.com/com/en/owners/bmw...ted-manual.pdf
      06-10-2015, 02:30 PM   #6
Peter_R
Air Vice Marshall
Peter_R's Avatar
Just so that there is no misunderstanding about this. The thread heading says...
That is what I am answering here. Nothing more and nothing less.
In my car everything else in the App itself works perfectly on my Galaxy S5 using the latest version of Lollipop connected to the USB port. It is only the ECO PRO Analyzer part that is NOT working. I stated this in a previous thread.
Thanks
      09-05-2015, 01:28 PM   #7
Simpaty
Drives: Bmw 320d sedan F30
Got exactly same issue using Galaxy S4 i-9505 on android 5.0.1 and 2015 F30 BMW (hu-nbt).
Connected drive app works, eco anylizer just doesn't
      05-09-2017, 09:12 AM   #8
franzzz
franzzz's Avatar
Italy
142
Drives: BMW M4
Same problem with my Android and F30 with Hu-NBT
Any solution ?
BMW F82 M4 Black MHD CS Map - GTS DKG - Navi -Performance Brake RSL1 Pads - USB - DivX-DVD - Bluetooth - VoiceControl - Connect - Apps - Online - H&K - TrafficInfo - SpLimInfo - WhiteMerino- PDC - Cam - Adaptive Led - Antitheft - CP Steering- Performance ST - Adaptive CP Setup - GarageDoorOpen - Pipercross - Stock Exhaust - Mdrivers Pack - 437M Wheels
