      04-23-2015, 07:51 AM   #1
justindenton
Drives: 2005 X3 & 2009 335i
Random Knock on 05 x3
On my 05.. I have this random Knock.. When I start the car it runs fairly well for a few minutes.. Then it will knock or possibly miss for a couple seconds then run fine again.. The knock originally sounded like a really bad Vanos so I replaced the Vanos and still the knock persists..
Does Misfiring sound like a metal clanking noise? I believe I have a small tear in the intake boot which I temporarily taped shut to see if that helped.. But didn't seem to..
I've changed plugs as well since I was replacing the vanos and those looked pretty black. Oil levels and coolant levels look pretty good..
I pulled out the DISA and it looks good.. the Flap responds properly.. But I didn't disassemble it..
When idling this occurs.. When pushing down on the gas pedal it seems to go away while applying fuel.
Thoughts anyone?
Thanks
Justin
Tags
engine, idle, knock, rough
