      10-28-2023, 10:48 AM   #1
JOHNR1016
Drives: 2017 X3
2017 BMW X3  [0.00]
water leaking into front right door
I am getting water on the front right sill plate of my 2027 X3 after a heavy rain. The weather seal on the door also gets wet. There is no water in the X3. I checked the sunroof and windshield drains and they all work perfectly. I took the car to a body shop and they could not find any obvious reasons for the water. This morning I put a hose to the front door and found that when I sprayed the front mirror and window some water seemed to enter the door. I was able to see water dripping from the front passenger door towards the front of the door and the water was coming from between the door and the interior door panel.
Any ideas regarding how the water is getting into the door and what my next steps should be?
Thanks,
John
Thanks for your thoughts!
John
      10-28-2023, 01:48 PM   #2
carmoongia
Drives: bmw X3 F25
Most likely the door seal it is flimsy liner sealed around with butyl, you will need to remove the door card to inspect it but will be obvious when you see it , you may be able to reseal it with a heat gun common BMW issue unfortunately
Good luck 🤞🏿
      10-28-2023, 02:07 PM   #3
JOHNR1016
Drives: 2017 X3
2017 BMW X3  [0.00]
Thanks for the reply. I will check out door panel removal and see if this is the problem.
      10-28-2023, 07:44 PM   #4
383vett
383vett's Avatar
Does the other side do the same thing?
2016 Z06 Vette, 10.53@132
1984 Vette, 406, 10.23@131
2021 SQ5
      10-29-2023, 06:18 AM   #5
JOHNR1016
Drives: 2017 X3
2017 BMW X3  [0.00]
No. It's just the right side that gets wet. Luckily nothing comes into the car yet.
      01-19-2024, 11:36 PM   #6
Doc Roc
Drives: 2016 X3 Xdrive 28i
I know that this is an older thread, but I’m having the same issue(passenger front) on my newly acquired 2016. I will try the recommendation. Please update any information when possible. Thanks
      01-20-2024, 04:13 PM   #7
lidation
Drives: '13 X3 F25 w/ N20 engine
my '13 F25 once got flooded in the passenger footwell with an inch of water. I couldn't find the leak path. My sunroof drain was working fine, not clogged and I clean that sunroof drain regularly. The only thing that I can correlate to this mishap is that I park my car facing down the slope on my driveway. so I make sure I always park the car facing up the slope when it rains and I never had a flooding issue ever again. Don't know why.
