      01-18-2020, 03:02 PM   #1
vinodrk.1st
Drives: BMW X3
2013 BMW x3  [0.00]
130F20 Exhaust Camshaft: Offset angle to Cranksahft Outside Tolerance
Hello All,
I have been getting intermittent P1339 Error which after restarting the car goes away. Upon checking with ISTA i see 130F20 error Code(130F20 Exhaust Camshaft: Offset angle to Cranksahft Outside Tolerance)
The timing chain was replaced at 66k miles by BMW, the car currently has 98K miles. i did a visual inspection of the timing chain, it was tight enough.
Took the car to many mechanics all said the car was fine & no issues.
Took it to BMW, they said timing chain is stretched & has to be replaced, but i chain is tight enough i cant even move it.
Every time before this warning of P1339, i see a undervoltage on Terminal 15 log. is this causing the P1339 error?
Vehichle takes atleast 15 -20 mins to reach operating temperature of around 190 degree Farenht
Could any one please help?
      01-19-2020, 10:15 AM   #2
willywi
Drives: BMW x3, BMW x5
There is a lower portion of the chain that will get stretched too.
      01-19-2020, 09:18 PM   #3
hardparker
Father of Frankenfold
299
Drives: Yo daddy's 2014 X3 M Sport
2013 BMW X1  [0.00]
2014 BMW X3  [0.00]
N55 or N20? Ever been over-revved? No motor should have required timing chain replacement at 66K miles. N20 timing chain setup sucks and has extended warranty because of it, up to 100K miles.
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
      01-19-2020, 10:42 PM   #4
willywi
Do you have a link that says it's been extended to 100k miles? I thuoght they only extend it to 70K.
      01-20-2020, 08:08 PM   #5
hardparker
299
2013 BMW X1  [0.00]
2014 BMW X3  [0.00]
I may be misremembering. I don't track N20 stuff too closely.
      10-30-2021, 02:10 PM   #6
chitangi
Drives: bmw 328i
N20 in time but keeps getting error 130F20 and 130E20
Hey guys I recently changed my timing chain and all. I keep getting the error 130F20 and 130E20 for some reason. Checked my live data, my readings are constant ZERO dead flat. each time i start the car I get a delay ,I have less power, the idle is perfect ! Once I clear the codes while running the light stays off until until when I restart the car again....Could this be an electrical DME issue ? tested the camshaft sensors and they checkout good. Thanks again for your feedback.
      04-29-2022, 04:56 AM   #7
Androy
Drives: X3 F25
Hi,
have you solved this problem? what caused it, what needed to be replaced?
I have a similar problem, I get an error:
130E20: Inlet Camshaft: Angular offset to crankshaft outside tolerance
120408: boost pressure control: shutdown as a following-up reaction
the car runs at reduced power.
Thanks for the help
      11-29-2022, 08:11 AM   #8
Waterjan
Drives: 2013 X3 2.8i
errors130f20 and 130E20
Did you manage to resolve it? I have same problem, chain was replaced 30,000km ago
      03-03-2023, 04:39 PM   #9
farhad_uddin
Drives: bmw
Originally Posted by Androy View Post
Hi,
Thanks for the help
Hi there, did you manage to solve this issue? Getting the same errors after timing chain replacement and multiple checks of correct timing.
      11-13-2023, 02:00 PM   #10
chiefseol
Drives: 2013 bmw 320i f30 n20
bmw codes 130e20 and 130f20
i watched a you tube video about this exact situation and it says if you have a stretched chain and it you replace it without switching out both the vanos sprockets at the top then you will get these codes 130e20 and/or 130f20
      01-02-2024, 08:26 AM   #11
Bmw turbo
Drives: Bmw m235xi
Hi,
Thanks for the help
Have you solved this problem? I have the same codes on my car and can’t find out what it is. Thanks
      01-16-2024, 02:52 AM   #12
s55mikeyZ
Drives: BMW F80 M3
similar Problem
So i Spun my crankhub and had a gintani one put in then was running perfect for a few months. Then Same Code again 130E20 and 130F20 i fixed it again by replacing the vanos sprockets. I recently had one of my injectors fail and when i went to reset adaptations after raplacing all 6 the same codes came back im really lost LMAO
Tags
camshaft position, exhaust camshaft, terminal 15 error, timing chain
