      09-19-2020, 10:57 AM   #1
TXSAW
TXSAW's Avatar
Drives: BMW 2017 X3 F25
X3 F25 DRL coding
Anyone have luck coding the DRLs to LED?
      09-19-2020, 12:50 PM   #2
malkie0831
Drives: BMW X3 3.5D Msport
If you have a car with halogen headlights and the W21W DRL bulbs in the Hi/Beam lights, then yes I have done it.
I contacted BimmerCode support and they gave me the following:
please try the following using expert mode:
AUSG_17_BL2_L_WARM_UEBERW_AKTIV -> nicht_aktiv
AUSG_17_BL2_L_KALT_UEBERW_AKTIV -> nicht_aktiv
AUSG_18_BL2_R_WARM_UEBERW_AKTIV -> nicht_aktiv
AUSG_18_BL2_R_KALT_UEBERW_AKTIV -> nicht_aktiv
AUSG_17_BL2_L_IS_LED -> aktiv
AUSG_18_BL2_R_IS_LED -> aktiv
It worked for me.
      09-19-2020, 10:25 PM   #3
TXSAW
TXSAW's Avatar
It worked for me.
Awesome, I really appreciate the response. I've been searching high and low for this. I'll give those parameters changes a shot.
**UPDATE
This worked. Appreciate it. If anyone else is looking to change these parameters they can be found here:
      10-04-2020, 02:33 AM   #4
ALPx3
ALPx3's Avatar
11
Drives: 17 x3
It worked for me.
Will this work for my 17 stock halogen retrofitting over to oem xenon? I believe the ae are led correct?
I have almost completed the retrofit . The rewiring is done and my coder was a able to get the low beam xenon and turn signals to work. Currently having issues activating the ae drl. Would really appreciate the feedback. TIA
      10-05-2020, 01:58 PM   #5
ALPx3
ALPx3's Avatar
11
Drives: 17 x3
It worked for me.
      10-05-2020, 06:04 PM   #6
TXSAW
TXSAW's Avatar
It worked for me.
I'm not sure of the exact parameters for xenon retrofit, but I'd suggest adjusting those parameters, specifically the hot/cold checks. With a little bit of trial and error, I'm sure you would figure out with light is which. They may be exactly the same as the stock halogen setup but I can't say for certain.
Not much help, but hope it gets you in the right direction. goodluck.
