03-27-2012, 12:43 PM | #1 |
Rep 161
M Sport (UK) - cannot delete Sport Suspension if VDC?
Is this correct... you cannot delete Sport Suspension (on a UK M Sport) if you are adding VDC?
The dealer has said that he cannot do this (on the selector) and it is because the "Sport Suspension" is equivalent to "Sport" on the VDC, so you cannot delete it (but the VDC will give you an equivalent to "SE Suspension" in the "Normal/Comfort" mode). Obviously VDC adds some functionality other than the suspension stiffness. (sorry if this topic has been done before) QT |
03-27-2012, 01:38 PM | #2 |
Rep 412
Sound weird. I would have thought that your options on MSport would either be "Sport" suspension which is stiffer and has a fixed damper rate, or VDC which has variable rate dampers and two settings: normal or sport. When I checked on the UK website you just delete sports suspension, select VDC, and it tells you it's an additional £930. Which means your dealer is probably talking out of his a$$.
03-27-2012, 01:39 PM | #3 |
Rep 309
Given that VDC provides dynamic/adaptive suspension, it really doesn't matter!
Current 2016 F80 M3 Saloon, Alpine White & Silverstone Full Leather. Love it.
Past 2015 F13 M6 Coupe, San Marino Blue & Opal White Individual Leather. Gone but not forgotten. |
03-27-2012, 04:29 PM | #5 | |
Rep 161
Thanks everyone.
QT |
03-27-2012, 04:41 PM | #6 | |
Rep 161
Have just tried this and - assuming you are looking at an M Sport - it doesn't allow you to have both "Sport Suspension Deletion" and "VDC" selected at the same time: when you select the former then the later, the former gets unchecked again. QT |
03-27-2012, 05:04 PM | #7 |
Rep 449
On M Sport, Sport Suspension Deletion gives you regular suspension.
VDC supersedes both regular and sport suspension. By adding VDC you are effectively deleting sport and normal suspension to have a system which allows both or something analogous to both.
F25 X3 xDrive 35d M Sport Alpine White, Black Nevada Leather, Speed limit info, TV, Prof. Nav & Speakers, HUD, M Sport steering wheel, Sport gearbox, BMW Apps, Internet, VDC, Comfort with Powered boot, Hi-speed synch, VSS, Top View, Electric tow-bar, Heated steering, Storage, DAB, Heated electric seats, Moonroof, Adaptive High beam assist Xenons, Servotronic, Performance control, etc.
