      03-23-2012, 08:54 AM   #1
Rogerbu
Drives: X3 GO1 30e M Sport
Virually unlimited music via the USB
I have the USB port in the Centre Armrest that can play music from a memory stick etc.
The Handbook says not to use USB hard Drives or to charge an external device via the USB Port - I assume that the current drain for a USB Hard Drive or external charging device could be too high.
Therefore I am limited in number of tracks to my largest Memory Stick.
However
My USB Hard Drive (250GB came with an odd USB cable with an extra flying USB A connector specifically to pick up power. I also have a Cigerette lighter to USB Power adapter. Therefore I can power the USB Hard Drive from the adjacent Cigarette Lighter socket and connect the Hard Drive to the USB Port. See 1st jpg
The result is thaat I can have music (and I assume video) upto the storage capability of the spare USB Hard Drive.
The only limitation I found is that the iDrive doesnt seem to like the album folders not being at the root level.
I have dumped 20GB onto the hard drive and it seems very happy to randomly play from all the album folders. The lower jpg shows that I am playing 1 of 3752 tracks - that should take awhile before it repeats
      03-23-2012, 08:59 AM   #2
Markap
Drives: 2011 X3 2.8
I was able to find a 32G USB stick for $25 that holds the majority of my music. You are right - folders must be at the root level so I opened my iTunes folder and copied them directly out of there. Only difference between this and using an iPod is no playlist support and bands starting with "The" (i.e. The Band) are grouped in the "T's" instead of by band name as on the iPod
      03-23-2012, 03:41 PM   #3
roundtree
roundtree's Avatar
Drives: '12 F25 28i SB
2013 BMW 328i  [10.00]
2012 BMW X3  [10.00]
I have playlists in each folder that show up when I go under Playlists. Definitely easier than navigating the folder structure for me.
BTW, I don't have have the root limitation described. Most of my music files are a couple levels deep without much problem, oriented like: "Artists" is the top level, with a folder for each artist, and each album is a sub of that like : Artists->King's X->Gretchen. Hasn't been an issue since day 1.
For full disclosure, here's what I'm using: Verbatim Store 'n' Stay 16GB. Doesn't fit 100% of my music, but only the 6-8 GB I love to listen to all the time.
P.S. Roger, you'll find that your drive requires more power than a single USB port will provide. I'm pretty sure it requires both for the drive's power threshold (above 5V, I assume).
      03-23-2012, 07:19 PM   #4
Nahoa
Why is this better than plugging an iPod Touch into the center armrest and being able to access all it's music and playlists? Or is it that you don't have an iPod Touch (or similar) and are looking to use what you have already?
      03-25-2012, 03:58 PM   #5
Bustofa
Drives: F25 X3 XDrive20D SE
No doubt this is drive dependent. I have had an 80GB 2.5" HDD plugged in to the USB only for the last 5 months without any problems.
      03-26-2012, 09:17 AM   #6
PGB
Drives: 2011 X3
I have a 250Gb drive connected to the USB drive in the centre console. Have had it plugged in for about 6 months and its doing fine.
Main thing to think about is you have to use a 5400rpm drive instead of a 7200 rpm drive as the faster drive needs more power than the USB port puts out. I did this so I would still have the lighter port for charging phones or using the ipad (by the passenger!). I use the front port for SatNav when needed.
My drive has 25,000 songs and I have it on random and its great. The only issue is the spin up time can a minute or two given its a slow drive with a lot of songs. I've had no issues with folder structures on the drive.
      03-26-2012, 10:14 AM   #7
plymjack
Nuclear Chief of the Watch
plymjack's Avatar
Drives: X3 (F25) 2.0D, i3 BEV
The point is why waste money on an Ipod when a usb stick works just as well.
So thanks to OP for the details - My X3 arrives in May and I have a 64gb USB fully loaded ready for it.
      03-26-2012, 02:25 PM   #8
Markap
Drives: 2011 X3 2.8
In my case my iPod died and I didn't want to connect my iPhone all the time as I would probably forget to take it out. So, a new iPod was a couple hundred dollars versus a USB stick at <$30. A "no brainier" in my opinion (I already spent $$ adding a trailer hitch)
      03-26-2012, 02:49 PM   #9
Markap
Drives: 2011 X3 2.8
      03-26-2012, 02:49 PM   #10
Markap
Drives: 2011 X3 2.8
      03-26-2012, 05:30 PM   #11
Markap
Drives: 2011 X3 2.8
Hmm. No delete.....sorry for the multiple posts. iPhone issue....
      03-26-2012, 05:42 PM   #12
roundtree
roundtree's Avatar
2012 BMW X3  [10.00]
That was the main reason I went for a really, really small drive. Leave it in place and it doesn't take up any substantive space in the console. My only real gripe is the lag from the time the car starts to the time the drive is mounted and fully usable, but it's not unbearable (maybe, 60 seconds tops?).
      03-26-2012, 05:56 PM   #13
Nahoa
Gotcha. Cool deal!!
