      03-31-2014, 07:44 PM   #1
flash3
Drives: X3 28i
Wind Noise 2011 X3
Hi All
Wanted to see if anyone else has experienced increase wind noise in their X3? Over the past few weeks it's getting to the annoying point.
Have you guys taken into the shop? Was it resolved? If so, how?
      04-01-2014, 02:35 AM   #2
clivem2
Drives: X3 M40i
It can be improved if the cause is the rubber scrapper at the bottom of the from windows.
http://x3.xbimmers.com/forums/showthread.php?t=591028
Previous: E30 318iS, E39 520i 523i 523i, E46 vert 330i 330i, E93 vert 335i, F25 30D 35D
      04-01-2014, 05:45 PM   #3
flash3
Drives: X3 28i
and if it's not?
      04-02-2014, 12:30 AM   #4
Booty
Enjoying it!
Drives: X3 3.0D M
Turn the music up...
      04-02-2014, 02:35 AM   #5
clivem2
Drives: X3 M40i
I meant to type "front" windows.
If the cause is something else then I don't know what can be done as you need to track down the cause.
      04-02-2014, 07:31 PM   #6
flash3
Drives: X3 28i
def front windows - front door area - do you think changing the foam around the door will make a difference?
      04-03-2014, 02:46 AM   #7
clivem2
Drives: X3 M40i
All you can do is experiment. I would change anything yet but I would add to stuff like the foam if you feel that's where it's coming from. Fine some other foam you can put in place in strips. The whole door sealing arrangement is not great, it's not really sealed from the outside as the seals are more internal.
