      03-12-2014, 05:52 AM   #1
Sireal
Sireal's Avatar
Drives: 2014 X3 xDrive35i
Sports mode question
If you move auto shifter to left and go into the mode where you see the "S6" etc gear, is that the same as engaging the sports mode button on the console, where you see ("D" sport) on dash, or if you do both you see ("S6" sport) on dash. Is this redundant? Could someone clarify.
2014 X3 xDrive35i, Black Sapphire; 2008 Z4 3.0si Roadster, Space Gray, 2005 F-150 Lariat, Crewcab, 5.4 Triton, Burgandy
      03-12-2014, 08:03 AM   #2
The X Men
Drives: 2013 X3 35i
If you put the shifter to the left, it will go into DS mode. If you don’t push the shift up or down to manually shift, it will shift by itself and stay in DS mode instead of the manual shift mode. Pushing the sport mode button will do the same as the DS mode plus it will stiffening up the steering wheel. If you have adaptive suspension, that will stiffen up in the sport mode as well.
      03-12-2014, 08:04 AM   #3
n55x3
Drives: n55 BMWs
When in normla mode, clicking the shifter to the left puts you in DS. This initiates a more aggressive shift pattern. Holds gears longer, downshifts sooner under hard breaking etc...
When you leave shifter in normal position and toggle to Sport mode, depending on your options you can have a few things happen. Steering tightens, DS shift patterns are engaged (same as just clicking shifter to the left), suspension firms up.
So essentially, from a transmission perspective, the 2 are the same but you have the possibility of enahncing other variables when you toggle to sport mode.
      03-12-2014, 02:47 PM   #4
kdog26372
Drives: 2015 M235xi BSM
I also notice when you push sport mode button that throttle response is more aggressive and when shifter to the left, the auto start/stop is de-activated until you put it back to middle.
'15 M235xi | BSM/Oyster/Aluminum | Black Kidneys | RW Carbon Mirror Caps | 40% tint
      03-12-2014, 03:43 PM   #5
rbtamms
rbtamms's Avatar
Philippines
63
Drives: 2011 E90 and 2013 F25
2011 328i  [0.00]
Whenever I'm entering the freeway, I always switch to Sport Mode & move the shifter to DS Mode as well. The response is really quick & it's fast enough that I seldom use the manual shifter.
      03-12-2014, 04:42 PM   #6
flavius
Drives: 2019 440i Gran Coupe
What good does it do if you do both? Isn't turning on SPORT MODE enough?
-Experienced driver; cocomats
      03-12-2014, 08:19 PM   #7
BeeMdblU
BeeMdblU's Avatar
Drives: F86, F25, G16
also if I'm not mistaken the second tip of the exhaust opens up and it gets a little louder
      03-12-2014, 09:21 PM   #8
bsxdrive35i
Drives: X3 xDrive35i
I believe that it still does make a difference. Whenever I am in Sport/Sport+ and throw the gear selector to the left, the transmission shifts down. I'm pretty sure it holds the gears a little longer versus having the drive mode in Sport/Sport+ without having the gear selector to the left.
F25 X3 xDrive 35i - E66 760Li - E46 330xi (sold)
      03-13-2014, 10:22 AM   #9
pokerface
pokerface's Avatar
Drives: F25 X3 N20 / F80 ZCP
It seems to make a difference to toggle both to Sport and DS. From Comfort mode at a given speed, going into Sport will cause a downshift and then going into DS triggers a second downshift for me.
      03-15-2014, 12:50 PM   #10
clivem2
Drives: X3 M40i
Agreed, if I'm in Sport via the button and move the stick to DS I get a downshift. I would be great if BMW could explain how all the modes work.
Previous: E30 318iS, E39 520i 523i 523i, E46 vert 330i 330i, E93 vert 335i, F25 30D 35D
      03-15-2014, 08:15 PM   #11
xDrive35i
xDrive35i's Avatar
Drives: Porsche Macan S
There are so many threads about this.
      03-16-2014, 12:29 AM   #12
flavius
If there are then there should be a sticky, right?
      03-16-2014, 09:45 AM   #13
xDrive35i
xDrive35i's Avatar
I mean I don't run this forum.
      03-17-2014, 07:58 AM   #14
HighlandPete
Drives: BMW F11 535i Touring
Shame BMW only explain the basic functions, even in the technical data. I agree it would be good to know the exact changes in the modes. For example, why the Sport Mode is like a 'halfway' change to the gearbox, rather than the full Sport program. BMW simply list the change to the Sport program, but clearly the change points/characteristics are different in the "mode" change, compared to a stick change.
My 5-series works the same way, Sport Mode only gives one down change, at cruising sped, whereas flicking the gearstick to M/S gives another down change. Sport+ gives a double shift change at the same road speed.
HighlandPete
      03-17-2014, 09:00 AM   #15
flavius
Somebody does.
      03-17-2014, 11:13 AM   #16
RhoXS
Drives: 2002 Z3 3.0i + 2016 X3 28i
Maybe, since setpoints, logic, and available features, are now heavily determined by software and easily modified, BMW must be guarded in what they advertise. In the absolutely inane litigious world we live in, if the #$%*#%$# lawyers can find a way a woman can sue someone because she spilled hot coffee on herself, imagine what BMW would be up agaianst every time a software update changed a shift setpoint, available feature, etc.
      03-17-2014, 01:23 PM   #17
xDrive35i
xDrive35i's Avatar
Probably nothing.
      03-23-2014, 12:12 PM   #18
clivem2
Drives: X3 M40i
HighlandPete
I get the feeling that DS + Sport = Sport+ but with full traction control.
Does this seem about right?
      03-27-2014, 11:14 PM   #19
ryanburk
Drives: X3 F25
Thumbs up
this is the greatest thing I didn't know about my car. thank you so much!
      03-30-2014, 08:36 PM   #20
pokerface
pokerface's Avatar
So what do you guys get when you toggle Sport+ and DS? I don't have Sport+ on our x3
      03-31-2014, 09:26 AM   #21
lbjgh
lbjgh's Avatar
Drives: 2013 AW X3 M-Sport
What he said.
Depending on settings when you select sport mode the transmission will revise its shift patterns and be limited to 7 gears. 8th gear can be selected with the paddle shifter (if equipped) but the trans will revert to 7th gear if left in D.
If you shift to DS and sport mode the shift pattern will be even more aggressive and (if I recall correctly) will still max out at 7th gear. While in DS the trans will maintain a selected gear until manually changed of you decrease vehicle speed.
