      07-28-2012, 05:33 PM   #1
Markap
Drives: 2011 X3 2.8
Traction control questions
Ok, other than just to try it out/have fun, has anyone found a reason to turn off traction control or go into Sport+ mode? Ifso, what conditions? Also for the folks that went to the PDC, did they talk about traction control? Seems like it would only work under power or increasing power - so, if you go into a turn hotter than expected or slippery, are you better off just adding gas (petrol) and letting the traction control do the rest or what?
      07-29-2012, 08:23 AM   #2
greierasul
electrical engineer
Romania
Drives: X3 - 2.0 L diesel- 184 CP
Control traction off it is very important in a winter times. If your car is stuck in the snow and will want to accelerate, the control traction will cut off the gas.
      07-29-2012, 09:51 AM   #3
Markap
Drives: 2011 X3 2.8
Good info. Any other times? How about running too hot into a curve ( maybe slippery too)?
      07-30-2012, 08:14 AM   #4
n55x3
Drives: n55 BMWs
When it rains or the roads are wet and I'm feeling frisky I turn off the t/c and it allows for a good bit of oversteer. I can probably get the back end out about 15-20 degrees before it intervenes. With t/c activated you can't get the back end to step out at all.
