      03-02-2016, 12:13 PM   #1
KB29R
Drives: X35D
no oil after BMW Service
I own an X35d and took it to a main dealer for its first service - when I got it home to my horror I realised that there was a smigen of oil in it alerting me to pull over and put oil in it
Is there a possibility the engine has been put under stress driving 20 miles without sufficient oil in it - to say that I'm slightly p****d off is an understatement
Ken
      03-02-2016, 01:07 PM   #2
HighlandPete
Drives: BMW F11 535i Touring
Ken
It depends.... on answers to factors like, is the sump empty? Or are you simply requiring a top up? Was it not topped off properly, or has it lost oil on your trip home?
I'd suggest if the sump was empty, you'd have had immediate warnings, oil pressure would be compromised.
Let's hope it is simply an error, (still not good enough from a BMW dealer), like filling with 2.0d oil volume, rather than 35d oil capacity.
      03-03-2016, 12:24 PM   #3
KB29R
Drives: X35D
It was its first service at 13000 miles - from the gauge on the dash it was very low telling me to pull over and put some oil in it as its below minimum
The oil was simply not topped up at the Main Dealer - the job was not done - not even checked - I find it totally unacceptable and will be sitting down with the MD on Monday
      03-03-2016, 12:42 PM   #4
The X Men
Drives: 2013 X3 35i
If you have been driving 20 miles and the display ask you to top off the oil at the end of the trip and your oil pressure is ok, it probably just a half of quart low, I would not make a big deal out of it.
      03-03-2016, 04:38 PM   #5
MichiganMike
Drives: 2016 X3 xDrive 35i
2020 X3 M40i  [0.00]
2016 BMW X3 35i  [0.00]
My understanding it that it may be better for your engine to be a quart low than to have the oil overfilled by a similar amount. For the dealer to not top up the oil properly is not acceptable, but it could be worse.
http://www.bimmerforums.com/forum/sh...th-Oil-hurt-it
      03-04-2016, 04:00 AM   #6
plymjack
Nuclear Chief of the Watch
plymjack's Avatar
Drives: X3 (F25) 2.0D, i3 BEV
It sounds like a genuine mistake, even BMW Tech can make them, not good but I doubt any damage was done. Im sure the dealer will ensure you are well compensated for your trouble and inconvenience.
BMW X3 (F25) xDrive20d SE 2017. . . . Oyster Leather . . 8 Speed Servotronic. .RFTs. . Electric Seats
Canon 70D 500mm, 85mm, 40mm, 24mm
Sony QX10 & GoPro Hero 3
      03-04-2016, 06:31 AM   #7
Smithy2014
Drives: X3 2.0d msport Auto
Which dealer did you use? I have mine booked in with the one in the centre of brum in a weeks time...
Now - LC1 20d Carbon Black
Gone - F25 20d Space Grey
      03-04-2016, 08:57 AM   #8
KB29R
Drives: X35D
Big Deal? are you serious? what is a quart low?
Its not the Centre one - but if I was you I would ensure that they put some oil in it..
      03-04-2016, 10:15 AM   #9
The X Men
Drives: 2013 X3 35i
Yes, I am serious, just top it off and be on your way. Life is too short to have a heart attack over small things like this. You do realized that your car holds 7 quart of oil, half of quart low is not a big deal.
      03-04-2016, 11:26 AM   #10
KB29R
Drives: X35D
I admire the nonchalance - you must be a retailers dream when things go wrong, although you have your facts wrong in regards to the amount of oil that was in there
For me, the fact that a main BMW dealer sent me off after its initial service with below minimum oil levels is something I will not ignore - it also seems by the tone of the Managing Director of the group that it is absolutely unforgivable that a customer whom invested £50,000 of his hard earned cash to the dealership to be treated in this way
I fully accept mistakes can happen - as long as its fairly compensated
No heart attack here - just simply ensuring that the mistake is rectified and will never repeat itself ever again
      03-04-2016, 12:33 PM   #11
The X Men
Drives: 2013 X3 35i
So why don't you enlighten us, how much oil were you low? And what kind of compensation would you like for a quart of oil? If I am a retailer's dream, you must be their nightmare
      03-04-2016, 04:05 PM   #12
KB29R
Drives: X35D
It seems as though you have that 'quart of oil' stuck in your brain for some reason - you need to erase it somehow if you can
When I went into the display gauge menu it barely registered that there was anything in it - just registering on the display
nightmare! - their worst ever
      03-04-2016, 05:10 PM   #13
gIzzE
gIzzE's Avatar
363
Drives: F11 + 911 C4
Calm down a bit.
He was just trying to reassure you that if you drove home and then the light came on it was just slightly low on oil and no damage could have been done at all.
You do know what a quart is yeah?
A quarter of a gallon, a US gallon at that.
So it means you are around 400ml low, if it came on when you got home.
The difference between min and max is 500ml from memory.
It happened to me on my E350 and on my 335i after a service.
They used to tell you to check the oil level after a few miles and leave a litre in the boot.
Sit down with MD on Monday.
Brilliant, that tickled me.
      03-04-2016, 06:31 PM   #14
The X Men
Drives: 2013 X3 35i
I had the low oil warning a few times, when the idrive oil level display goes below minimum, it is only 1/2 quart to 1 quart low. If your oil level is dangerously low, you would have a low oil pressure warning and the engine management system would have put the car in limp mode.
