      02-17-2016, 07:16 PM   #1
happy_chrissy
Rookie
22
Drives: 2015' X3 28i
Wheel alignment at 19K on a 2015 X3
I brought my car in for an oil change and was told that I need to get a wheel alignment and to get need to clean out the fuel tank b/c it has too much soil or something in it from the fuel? Needless to say the gas/fuel tank thing I passed on but I told them to do the alignment.
      02-17-2016, 08:19 PM   #2
ba ba boosh
Drives: Jalopy
Wheel Alignment should usually only get done when just had new tires installed. Other than that it's a scam to up charge the bill. And that fuel tank cleaning sounds like total BS all together. I have never heard of that one. You should go back to the shop and kick the service adviser in the groin.
      02-17-2016, 09:56 PM   #3
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
at 19k miles is still not needed for an alignment, and if you do get curious there's a few shops with the Hunter 3d Hawk Eye that is able to show you pre-alignment and post-alignment to see where and if so you need one.
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
      02-18-2016, 05:56 AM   #4
Tjalle
Drives: X4 35i
What reason did they give for alignment? Since they did it - before and after?
Fuel tank? Dirt in oil spilling out in fuel?
      02-18-2016, 06:44 AM   #5
nyalpine90
nyalpine90's Avatar
7433
Drives: MY24 G01 AW Msport
2016 BMW X4  [9.33]
service shop that i go to have wheel alignment machine at the entry.While you wait for you service adviser the car is being checked.
      02-18-2016, 06:50 AM   #6
MichiganMike
Drives: 2016 X3 xDrive 35i
2020 X3 M40i  [0.00]
2016 BMW X3 35i  [0.00]
If I were you I would begin by replacing the service adviser. The SA clearly appears to be malfunctioning in a manner to siphon money from your wallet.
I once asked my SA whether I should consider a wheel alignment. His response was it was likely a waste of money unless the tires were showing unusual wear or the handling suggested misalignment.
Unless you have reason to believe your fuel tank was directly contaminated, there is no reason to clean the fuel tank. The fuel filter is designed to keep contaminants from reaching critical parts. At some point you may need to replace the fuel filter.
      02-18-2016, 08:25 AM   #7
Barbera335
Drives: F25
+1 on this
And I strongly suggest keeping the SA that dissuaded you from the alignment. Good honest SA are hard to find.
      02-18-2016, 12:17 PM   #8
The X Men
Drives: 2013 X3 35i
happy_chrissy, If the dealer found the fuel filter to be dirty, you should probably start another gas station or try not to gas up when the gas tanker is filling up the gas station's underground tank.
      02-18-2016, 12:38 PM   #9
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
Originally Posted by Barbera335 View Post
+1 on this
+1
Stick with any TopTierGas.com Retailer, I use shell 90% of the time, been rotating with Costco Premium the past 5 months since its the cheapest price on debit or credit. Shell/76/Valero are my fav for how they feel when i press the pedal.
IG: @bmwF9XG80
      02-18-2016, 02:14 PM   #10
Pinewood
Pinewood's Avatar
Drives: BMW X3 30d M sport LCI
Always rotate your fuel stops and put in some premium fuel every 4th fill up. Supermarket fuel is renowned for being inferior here in the UK
      02-18-2016, 04:04 PM   #11
gIzzE
gIzzE's Avatar
363
Drives: F11 + 911 C4
Don't you guys use premium fuel anyway?
What do you class as premium? 93 Octane?
These cars have knock sensors and retard the timing considerably if you use lower octane, 87 will loose you a fair bit of BHP and MPG.
how much extra is premium at the moment?
I know my 335i lost 40hp on regular gas, and around 15% down on mpg too.
      02-18-2016, 04:27 PM   #12
Commerce
Drives: 2019 X3 M40i
Isn't the car recommended premium only? I know if I don't fill up with premium I don't get the same performance.
      02-18-2016, 07:33 PM   #13
happy_chrissy
Rookie
22
I always use premium, normally BP(a few blocks away) Exon or Sunoco.Maybe I should try Exon or Sunoco more often.
I agree good SA are hard to find!
I did test drive it and it feels little sturdier than before. Plus, two weeks ago, my steering wheel did shake a lot when I was driving. I thought that there was tar on my tires and it lasted for a good 4 minutes but stopped, so I wasn't too concerned.
Thank you for the recommendations of the shops. I will go there next time, you live and you learn, oh well.
The fuel tank or injector with debris, didn't have them change it. I am thinking I may wait to the 2017 comes out and just trade it in and get DHP, which I didn't get on this 2015...
      02-19-2016, 12:02 AM   #14
xdriv3
Drives: X3
The minimum is 89. I haven't tried it yet. Any else can comment?
      02-19-2016, 07:47 AM   #15
ba ba boosh
Drives: Jalopy
Technically you could put regular, but your gas mileage would suffer quite a bit.
      02-19-2016, 12:54 PM   #16
Tjalle
Drives: X4 35i
My 35i is happy with 95, while my 1972 Jensen Interceptor 440 6-pack wanted 98 and additional lead and then additional soup-up additives.
      02-19-2016, 06:01 PM   #17
gIzzE
gIzzE's Avatar
363
It maybe happy but it will be down between 25-40hp running on 95. This has been proved time and time again on rolling roads over the last few years.
      02-20-2016, 05:23 PM   #18
Pinewood
Pinewood's Avatar
In the Uk we have regular diesel and premium diesel such as Shell's VPower.
I tend to fill up with regular diesel from Shell,BP and Esso. In addition I will fill her up with Shell VPower every 4th tank full. Never had an issue with my E60 530d and see no reason to change my fuel habits for the F25 (unless you gents tell me otherwise?)
2014 X3 30d Lci M Sport in Black Sapphire. Pro Nav, Black Leather,Adaptive Xenons, Extended Storage, Lighting Package, 19" Staggered (622M) summer wheels, 17" style 304 winter alloys
      02-22-2016, 07:07 AM   #19
BOSSBMW
Drives: 2013 X3 35i
Ive been using 89 for my past 3 fillups and have not noticed any detriment to power. It's probably SO negligible anyways...
['13 X3 SGM] [20" XXR550's in Black Chrome] [Lamin-X Tails/Fogs] [M-Sport Rear] [FOX Exhaust][H&R Sport Springs][RaceChip Ultimate][BMS N55 Intake]
SOLD-['06 325i TiAg] [19" VMR VB3 HYPERBLACK] [Blacklines] [OEM Xenon Conversion] [35% Tint] [M-Tech Rear] [M-Tech Front] [Black Vinyl Roof] [Slotted/Drilled Rotors, Cool Carbon Pads] [PBX]
      02-22-2016, 11:06 AM   #20
gIzzE
gIzzE's Avatar
363
Here is a graph for the 35i, the biggest difference is from 5000rpm.
Remember 95ron is like your 89 and 99ron is like your 93.
      02-22-2016, 02:14 PM   #21
The X Men
Drives: 2013 X3 35i
The savings in using 89 is also negligible
      03-01-2016, 06:48 PM   #22
alleyooptroop
Drives: 2015 x3
i'm about to bring in my 2015 for 21k service and I'm sure I'll get the reco for alignment. I did just upgrade the 18" 307's to a staggered 19" setup. haven't noticed anything wrong with steering.
-should i get the alignment done?
-is it a 4 wheel alignment?
-how much did it cost?
