      01-11-2024, 06:38 AM   #1
mdimike
Drives: BMW x3
Can bad fuel pump cause no crank?
2005 with 226,000 miles. Original fuel pump.
Intermittent no crank. I removed rear seat and thumped on the fuel pump assembly with a hammer. Car started. Is this a coincidence?
My question: Shouldn't the car crank even if the fuel pump is bad, or does the computer need fuel pressure to satisfy criteria before allowing cranking?
Thank you!
Mike
      01-30-2024, 11:07 PM   #2
mr2mike
Drives: X3
Yes it should still crank. Check to see if starter is getting power.
Can also see off the fuel rail if you're getting fuel pressure.
