      10-31-2022, 02:06 PM   #1
MPDev
Drives: BMW X3 (F25)
PFC F25 Issue
I've got the below issue. Ran a scan on an OBDII and got no error codes. Listened to them to see if I can hear any of them clicking and can hear nothing. Tried WD40 a few times and still getting the same issue. [IMG][/IMG]
Separate issue, windscreen washer fluid constantly showing as needing topping up but it's full. Could this be a sensor issue? Again not showing up on the codes.
      10-31-2022, 09:12 PM   #2
brianhinton77
Drives: 2011 X3 28i, 2016 X5 M-Sport
What did you use to scan with? High probability it is a sensor
      10-31-2022, 09:53 PM   #3
Opie55
Drives: '15 650i Convertible
Your parking sensors are totally sealed electronic units. No moving parts and they make no sound. WD40 will do nothing. Also, an ordinary OBDII scanner will not "see" a system like that. OBDII systems were developed for pollution control and thus only read sensors related to how the engine is running. You need a scanner that reads all BMW codes in all control modules.
      10-31-2022, 09:54 PM   #4
Opie55
And yes, your washer fluid is probably the sensor in the tank.
      11-01-2022, 05:01 AM   #5
MPDev
Thanks
Thanks - what scanner would you recommend?
      11-03-2022, 11:02 PM   #6
brianhinton77
Fox well NT510 is a great handheld scanner…and if you want to I go deeper, you can find and download ISTA+
MPDev2.50
      11-05-2022, 06:06 AM   #7
richardodn
Drives: '12 X3 35iX/'20 440ix cabrio
I'd recommend the Foxwell NT530 over the NT510 Elite. Same basic functionality but newer hardware.
1986 Delphin 528e - Roof rack equipped lumber hauler.
2008 Platinum-Beige X3 3.0si - Current project
2012 Alpine White X3 xDrive35i - My new snowmobile.
2020 Estoril Blue 440i xDrive cabrio w/MPPSK - This car is a blast to drive.
