10-27-2022, 08:16 PM | #1 |
Rep 6
X3 Purchase Decision - Two Options
I leased a 2016 28i about 4 years ago and am thinking about getting another X3.
I'm looking at two 2014 X3 35i and don't know which one is the better option. Both are fully loaded M Sport xdrive 35i with the only difference being that one has the automatic high beams and the other doesn't. The main differentiator is mileage and price. Option 1: 57k miles for $24k Option 2: 97k miles for $17k Whichever one I choose I'm going to keep for around 3 years and 40-50k miles. Which one would you choose? |
10-27-2022, 10:07 PM | #3 | ||
Rep 188
Drives: BMW X5 and BMW 7 Series
Danyal.N55
10-27-2022, 10:32 PM | #4 |
Rep 6
Just what is on the vehicle history reports.
Option 1: Low Mileage 6,619 VEHICLE FLUIDS SERVICED 12,886 BRAKES SERVICED ELECTRICAL SYSTEM SERVICED LUBE, OIL AND/OR FILTER CHANGED VEHICLE FLUIDS SERVICED 19,486 MULTIPLE POINT VEHICLE INSPECTION LUBE, OIL AND/OR FILTER CHANGED 23,935 VEHICLE IN DEALER INVENTORY(COLOR REPORTED AS BLACK) CERTIFIED AS BMW APPROVED CERTIFIED PRE-OWNED VEHICLE 23,935 FUEL SYSTEM SERVICED BATTERY SERVICED OR REPLACED MULTIPLE POINT VEHICLE INSPECTION BRAKES SERVICED TIRES OR WHEELS SERVICE PERFORMED 23,941 TIRES OR WHEELS SERVICE PERFORMED FUEL SYSTEM SERVICED 27,160 TIRES OR WHEELS SERVICE PERFORMED VEHICLE FLUIDS SERVICED 36,742 MULTIPLE POINT VEHICLE INSPECTION 56,988 PASSED EMISSION INSPECTION (CA) Option 2: High Mileage 36,736 Sold as a BMW Certified Pre-Owned Vehicle 50,740 Tire repaired 77,418 Oil and filter changed Anti-theft/keyless remote battery replaced Engine/powertrain computer/module checked Vehicle washed/detailed 77,451 Windshield replaced 85,000 Maintenance inspection completed Oil and filter changed Spark plug(s) replaced Vehicle washed/detailed 85,029 Brake pad sensor(s) replaced Brake fluid flushed/changed Front brakes replaced 89,235 Cooling system serviced |
10-28-2022, 07:32 AM | #5 |
Rep 283
Drives: E46 M3 & LCI X3 35i M Sport
If it was me I wouldn't even consider option 2 unless it was incredibly clean with very good maintenance records.
If you can stretch your budget the LCI (to me) is a significant upgrade over the pre-lci. I have a '16 Melbourne red 35i M sport, glad I found it. |
10-28-2022, 08:11 AM | #6 | |
Rep 188
Danyal.N55
mwat125.00 |
10-28-2022, 11:25 AM | #7 |
Rep 2,908
You don't say why these 2 are the only options. Because they are local and you don't feel like driving elsewhere in Colorado or Salt Lake? Because they are both colors you love? Because they are cheap? X3s are pretty common so I would guess you have a pretty big pool to start from. I personally would opt for lower miles if I planned to keep it for 50k more, but if the higher mileage one seemed super-clean and was a color combo I preferred I could be persuaded, but I DIY everything, so that makes a difference.
10-28-2022, 01:16 PM | #8 |
Rep 6
What is the significant changes with the LCI? The pinned post got me under the impression the only changes were some minor cosmetics and the touchpad on the idrive controller.
10-28-2022, 01:49 PM | #9 | |
Rep 283
The interior is slightly different depending on your packages, if you get a 2017 you get a different steering wheel (assuming M sport) To me the exterior of the LCI is worth at least $5k over the pre-lci. If the LCI M sport is a 10/10, the pre-LCI is like a 6/10, in my opinion. See below side by side, admittedly I'm bias towards my own car of course... excuse the horrendous compression... |
10-28-2022, 11:02 PM | #10 |
Rep 176
That’s right…cosmetics…what gets me is the records on the vehicles. I would inspect both especially valve gasket sea and make sure there are no leaks. I like the idea of option # 2 having the plugs changed just 15K or so miles ago. Option #1 will need plugs coming up. If it were me, I would go with the cheaper more mileage car if it all checks out. Knowing you’re only going to have it a few years , you’ll have more money to save for wear items….just my .02
10-29-2022, 09:32 AM | #11 | |
Rep 3,549
I did plugs and coils for a couple hundred bucks in parts and it took only a few hours to do, it's not bad if you've got a little experience working on cars. Gives you an idea of about what a dealer or shop might charge. Trying to say that of course maintenance is a factor, if a lot is due, but this particular thing isn't too bad if there is otherwise a big price difference. |
