      03-12-2022, 08:42 PM   #1
Wgosma
Drives: 2012 F25 X3 28i (N52)
TPMS woes....
I just swapped my regular all-season wheels/tires back onto the car (removed winter tires). I can't get the darn iDrive TMPS readout to display Pressure and Temperature values - The units of measure (PSI and Deg F) are there but no values for any of the 4 wheels.
What to do??? (Both sets of wheels have working TPMS sensors).
      03-13-2022, 12:15 PM   #2
littleob
Drives: BMW e36ic, 2013 x3
When I switch my tires like your doing it might take a day or so for the on going tires this to work. This has happened the last few years
      03-13-2022, 01:56 PM   #3
Wgosma
Thanks, although that just seems a bit odd. When I installed the winter tires few months ago as I recall they synced in like right away, hmm….
The set I just installed show 4 'green' (I.e. properly inflated tires), on iDrive display but no press/temp values…..so the sensors must be communicating with the car's brain..
      03-13-2022, 02:22 PM   #4
littleob
I think the battery's in the sensors could be going. Only thing I can think of to cause my delay in communication.
      03-13-2022, 02:24 PM   #5
Wgosma
One of the 4 batteries is only 6 months old, all we're talking when I pulled the wheels off last Fall….something else going on here.
      03-14-2022, 07:00 PM   #6
39CAMC
Drives: 2015 x3 Xdrive
Even though I am in the tire business and do a decent amount of TPMS work, I am not always 100% sure what causes them to register and when. In general, they have pretty aggressive battery management to make them last so they are not always broadcasting.
It has nothing to do with battery life, however. And typical of BMW (and Mercedes) they seem to be a little "extra" with customers reporting that when I put new tires on the car, not moving the wheel to a different corner, that it can take 5-20 miles for them to "reset". No other car does this, some will show the light and it clears by the end of the street.
Specific to the battery issue, on my own X3, I put brand new wheels and tires with brand new sensors and it did the same thing the OP reported. I did the reset thing and it took a few miles for it to read them at all, but even after it did, it did not show numbers until a day later.
DaveW
      03-17-2022, 12:55 PM   #7
Wgosma
…5 days of driving and still no pressure and temperature data, ugh!
      03-17-2022, 02:44 PM   #8
KC87ZB
KC87ZB's Avatar
305
Drives: 2023 M2
I believe (can check later) there is a TPMS reset function in idrive - do that. I had to do that after a rotation so that the sensors and receivers match up correctly.
      03-17-2022, 03:13 PM   #9
Wgosma
Been there, done that …..a couple of times. iDrive shows all 4 tires in GREEN….but no press/temp data
      03-17-2022, 03:25 PM   #10
pungo
pungo's Avatar
Did you check the coding, maybe it somehow reverted back to the default with no press/temp values
      03-17-2022, 03:28 PM   #11
Wgosma
Yes, BimmerCode verified it's set to display press/temp….the units of measure are there on the iDrive screen, just missing the actual data
      03-21-2022, 01:58 PM   #12
apanner
Drives: BMW X3 2013
my x3 2013 ... TPMS no data information
      03-21-2022, 03:39 PM   #13
pungo
pungo's Avatar
Do you have sensors in the wheels? If so you need to code it to see the data, if not, you'll never see press/temp data.
      03-21-2022, 05:11 PM   #14
apanner
Drives: BMW X3 2013
sensors working fine ..but no data display... im new to this car world..
give me link... how to code ? to see the TPMS data
thanks
      03-21-2022, 06:19 PM   #15
Wgosma
thanks
thanks
You need a coding device or phone app (and wireless adapter to plug into cars OBD port). Look up BimmerCode in App Store, that will enable you to code this tire pressure/temp display functionality.
      03-21-2022, 10:06 PM   #16
apanner
Drives: BMW X3 2013
Thanks for info...
which OBD wireless adapter is good for BMW x3... any suggestion
      03-21-2022, 10:09 PM   #17
Wgosma
Thanks for info...
I believe if you go on the BimmerCode site there are recommended compatible adapter models listed.
      03-21-2022, 10:58 PM   #18
pungo
pungo's Avatar
thanks
The reason I asked if you have TPMS sensors in the wheels is that some markets don't have them and instead use the ABS system, but you say they're "working fine" so I'll assume you know for sure that you have them
Name:  TPMS Coded.jpg
      03-22-2022, 11:40 AM   #19
apanner
Drives: BMW X3 2013
Attachment 2840927
I'm expecting same data information from car... but only green tires I'm getting... need to code...
my friend has Nissan his car ... while doing air fill... his car make horn sound once its correct pressure for each tire ... do we have such option in this car...
my car info...
My car USA made.. Canadian version
Code / Type F25 / WX93
Chassis Sports Activity Vehicle (5 Doors)
Market USA (left Steering)
Engine N20 (2.00 l / 180 kW)
Drivetrain All Wheel-Drive
Thanks
      03-22-2022, 03:05 PM   #20
pungo
pungo's Avatar
NO, use a proper pressure gauge...
Engine is susceptible to self destruct with known timing chain system failure.
      03-22-2022, 05:21 PM   #21
apanner
Drives: BMW X3 2013
Engine is susceptible to self destruct with known timing chain system failure.[/QUOTE]
my car driven 115k Kms only... maintained properly...with oil changes .. so far so good.. in 100k miles problems will start...?
      03-23-2022, 07:21 PM   #22
Opie55
Drives: '15 650i Convertible
my car driven 115k Kms only... maintained properly...with oil changes .. so far so good.. in 100k miles problems will start...?[/QUOTE]
Chains have been reported to fail at all different mileages, including much lower than yours.
