      01-30-2022, 12:07 PM   #1
alexdavies82
Drives: BMW X3 (E83)
Droning noise issue - Help needed
Hi all,
Some help please
I have a suspect differential on my E83 BMW X3 (2006 Auto). I am getting a droning noise at speeds above 40mph which doesnt appear to be from the wheel bearings.
I checked in ISTA and I do have a fault with the transfer box (it says I need an oil change) but from what I have read this doesn't cause such noises - Is that correct?
I need to solve a small oil leak on the differential anyway and so I was planning to remove the differential anyway to inspect it. Does anyone have any recommendations for the following:
1. Bearings and seals for the differential - BMW doesnt seem to sell the bearings
2. Any recommended diff refurbishers (I am based in the midlands but could travel if needs be)?
Thanks
Alex
      02-16-2022, 02:27 PM   #2
X Mon™
Reads books at a 4th grade level; I'm an enabler
Drives: X5 35d, 335i Msport, X3, 325iX
I assume your'e talking the rear differential. If so: https://www.bearings-online.co.uk/it...462014810.html
That said, i would check the rear U-Joint/Cardan Joint on the the driveshaft. They're prone to rust issues, and tend to get tight/try to seize. The result sounds exactly like a bad diff pinion bearing.
As to the transfer case, change the fluid. Having one decide to eat it's bearings is NOT a fun time.
      03-05-2022, 01:13 AM   #3
Trainer97
C.E.O.
Trainer97's Avatar
Drives: 2018 BMW M2, 2010 E83 X3
Originally Posted by alexdavies82 View Post
Hi all,
Some help please
Thanks
Alex
Have you sorted this yet?
I had an issue like you described on my 2010 x3 and it turned out to be muffler related. The flap in the right tail pipe was vibrating. I was convinced it was either wheel bearing(s) or rear diff. Glad it wasn't.
      08-05-2023, 09:30 PM   #4
ivanchen
Drives: Honada2018
check it out: https://en.tradebearings.com/bearing.html Replacing bearings is not a difficult task.
      12-24-2023, 11:51 PM   #5
jannickz
Drives: x3
Worn or damaged differential bearings are a more likely culprit for droning noises at high speeds. Replacing them could potentially solve the problem. You can check it at https://www.bearingforworld.com/
