      11-17-2021, 11:33 AM   #1
thenew3
Drives: 2020 X7, 2016 X3, 2021 MME
New recall for X3 with N20 engine
Just got an email from BMWUSA about a recall on my wife's 2016 X3 with the N20 engine. Looks like it's emissions related and requires an ECU code update.
      11-17-2021, 12:31 PM   #2
dtox9
dtox9's Avatar
Drives: '17 X5 F15
Thanks for the head's up...
Do you know the build date of your wife's X3 ?
      11-17-2021, 12:32 PM   #3
thenew3
November 4, 2015
dtox9336.00
      11-17-2021, 02:28 PM   #4
thenew3
For some reason nhtsa site shows no pending recalls, but the bmwusa site does show open recall for my vin.
      11-18-2021, 07:26 AM   #5
mike_MAN
Drives: 2015 BMW X3
Thanks, I was able to find this recall on the BMWUSA website for MY2015 after logging in.
      11-21-2021, 07:03 AM   #6
bcar
Drives: BMW x3 f25
I got that recall notice too, not sure i'm going to get it done. Car has been working great since 2016. Why mess with it when its a voluntary recall.
      11-21-2021, 12:55 PM   #7
thenew3
It could be polluting the environment or causing slow damage to some emissions control equipment or something else. They don't really give much detail on what it's fixing.
Next time I bring the car in for oil change, they'll likely do the recall at that time.
      11-22-2021, 06:58 AM   #8
shoman24v
Drives: 2018 330i, 2022 Highlander
Sounds like a de-tune. lol.
Gonna be a fucking headache to take the car in for this.
| 2018 BMW 330i | 30k Miles | M-Sport Package | Driving Assistance Plus | Premium Package | Executive Package | Harmon Kardon | Active Blind Spot Detection | PDC | Mineral Grey Metallic/Coral Red Dakota Leather |
| 2022 Toyota Highlander Platinum AWD |
      11-25-2021, 04:05 PM   #9
okayr
okayr's Avatar
Drives: 2014 BMW X3 xDrive28i
This is what im worried about LOL. The car is slow enough as it is. But if it fixes the quite-a-bit-lower-than-epa MPG that would be great!
Also wondering if they're flashing the whole car vs just the DME. I have a lot of coding done that I don't want to redo.
      12-30-2021, 03:24 AM   #10
tom2021
Drives: 2017 BMW X3 xDrive28i
Please find my reply in a new thread with a new title "Campaign 20E-A01 or ECR-B0001-21-002 (in Canada)"
      12-30-2021, 12:31 PM   #11
Nik65
Drives: 2014 BMW X3 28i
I had the same same recall also for my 2014 X3. It takes 2-4 hrs for them to update the module. Pro: maps looks updated with new interference, Cons: if you coded your idrive in the past, it'll be wiped out
      01-06-2022, 08:43 PM   #12
razzy530
razzy530's Avatar
Drives: 335i M Sport RWD
After the coding of the dme the car feels peppier and the menu items interface is faster
2013 X3 2.8iX
2013 335i M-Sport RWD
2007 530i RWD 6-Speed manual
BMWCCA MEMBER 397411
      01-06-2022, 09:13 PM   #13
pungo
pungo's Avatar
Since the multiple modules in the vehicle are set up in a tree type configuration with dependencies, my guess is all modules that need updating get flashed to ensure compatibility, not just the dme
      01-08-2022, 07:35 AM   #14
Fodaski55
Drives: 2013 X3 28i
Voluntary Emissions update Information
For all of you that have the aftermarket Apple car play installed,be aware as I found out at the dealer that the software will be deleted when the emissions update is done. I reached out to Bimmertech and they would have to re install this software.
      01-12-2022, 12:24 PM   #15
okayr
okayr's Avatar
Just got mine done yesterday. Took them about 2.5hrs (quoted 30min to 2hrs) It's a whole i-step update so it wiped all my coding except VO coding. Bimmercode did not recognize the car as the same so it wouldn't load backups.
Also, if you have a 2014 model and don't have Siri Eyes-Free (long hold speech button to activate siri) or the volume pop-up— they are available to code now! Some icons are new. The trip computer is notably completely different now. Menu transitions are much faster too.
I can't tell a difference in driving yet.
      01-15-2022, 10:57 AM   #16
Uncle John’s Band
Drives: BMW 2013 X3 F25
I just installed the Bimmertech MMI but it was plug and play. What software would they have to reinstall?
      01-16-2022, 01:08 PM   #17
Fodaski55
Drives: 2013 X3 28i
Emissions update
My dealer mentioned that any aftermarket software will be deleted such as the Apple Car play/MMI updates,if you do the emissions update.The software would have to be reinstalled through a Bimmertech vendor afterwards. I am holding out until my emissions light goes off and I am forced to do this upgrade
      01-16-2022, 09:09 PM   #18
joshaguirre
joshaguirre's Avatar
Drives: 2016 X3 xDrive28i F25
Just had this recall taken care of 2 days ago. I can confirm they will update the car's I-Level. It took them 2 hours to update my car, it is now on F025-21-11-535.
      01-23-2022, 09:06 PM   #19
Greenman7612
Drives: 2000 BMW 740iL
2017 BMW X3 si  [0.00]
2013 BMW 528ix  [0.00]
2011 BMW X3  [0.00]
According to my trusted service advisor, the engine is running too lean and making higher levels of CO than should be. I was worried that they would screw up a good thing. After reading this forum, I’m less worried.
I got recalls for 2013 528i and my 2017 X3.
      01-23-2022, 09:08 PM   #20
thenew3
If it was running too lean and they are reprogramming to run a bit richer, does that mean it's going to use more fuel thus making the mpg worse?
      01-24-2022, 06:20 PM   #21
warsaw
warsaw's Avatar
Drives: BMW X3
Thanks for the update!
      01-25-2022, 12:46 PM   #22
Opie55
Drives: '15 650i Convertible
Took mine in this morning for the recall, and soon got the text with my free inspection results with two "Critical" items - a new drive belt and oil filter housing gaskets for the low, low price of $1,006.00. Even BMW branded parts are only about $100 and those are easy jobs on an N20. Guess I'll go to dinner with the $900 I'll save.
