      02-10-2014, 01:51 PM   #1
2014MsportX5
Drives: 2014 X5 MSport
Rim/Wheel Question
The wife is picking up a 2011 X3 35i and will need winters. Looking online for a good used deal I found these, looks like they were probably from an X6, before booking an actual appt to try them on, anyone here know first hand whether they would fit?
thanks in advance!
Rim size - 8.5*18 offset is 48
Tire Size 255/55/18
      02-11-2014, 09:07 AM   #2
bagekko
bagekko's Avatar
Drives: Lots of BMWs
2018 M4 Vert  [0.00]
2006 Z4M Roadster  [0.00]
1995 540i  [0.00]
2008 BMW M5  [0.00]
2019 i3 Rex  [0.00]
2021 X7 40i MSport  [0.00]
Those rims might be ok but they will be 12mm closer to the strut, which is probably close to rubbing. Those tires would definitely not work, the spedo error is almost 5% as the tires are about 35mm more in diameter.
The rims would probably work if you ran a 12mm spacer all around.
      02-14-2014, 12:06 PM   #3
2014MsportX5
Thank you - a few replies on another forums said the same thing so we have crossed them off.
