      01-10-2012, 07:09 PM   #1
bunnn
bunnn's Avatar
86
Drives: like a grandma
Brake Upgrades for our X3?
Coming from my old cars B7 A4 with Brembo upgrade, and E92 M3 with Brembo upgrade, the brakes feel really soft and lacking in the X3. I realize this is relative to my experience, but I'm looking to solve by perhaps buying a BBK for this truck as well. I'm wondering if other existing kits(perhaps from an E90 or X5) would fit on the X3?
Thanks in advance.
Edit: I wonder if the X5/6M brakes would work on the X3?
Cheers
Ben
      01-10-2012, 08:29 PM   #2
bren
user
bren's Avatar
Drives: German Camaro
Are you experiencing fade due to over-heating, or unable to engage ABS and lock the tires?
      01-10-2012, 09:25 PM   #3
bunnn
bunnn's Avatar
86
No - none of those. Honestly, I'm looking for an upgrade mainly due to pedal feel, and my experience with better performance brakes. As I mentioned, it's all relative to my own experience, nothing wrong per say with the X3 brakes on its own.
Cheers
Ben
      01-13-2012, 09:00 PM   #4
AtlM5
Drives: 2012 BMW X3 35i
More than likely a new kit will increase breaking distances because it will throw out the f/r bias...another concern would be the parking brake but im not sure if its a part of the rear like some cars. your best bet is some motul brake fluid and stanless steel lines and maybe different pads/rotors
2006 BMW M5 2012 BMW X3 35i
2008 Acura TL 2005 Chevy 2500hd
      01-15-2012, 01:35 PM   #5
AtlM5
^+1
      01-16-2012, 02:52 AM   #6
bunnn
bunnn's Avatar
86
The F/R bias is not a concern for me, I've never done brake upgrades on just the front alone. If it was design as a full kit, then it will be bought as a full kit to address the F/R issue. That would have been a major concern for me at the track on my previous cars. That said, I did not realize our X3's brakes were so integrated or technologically advanced/attached. However, I don't think anything that has been mentioned on the X3 is unique to our cars. There must be a kit out there that already addresses these issues on other vehicle, and if a kit were to be released for this car, I certainly expect it to be fully functional and integrated.
The line and fluid is probably my best solution at the moment, but I do hope to have a more complete package going forward. Thanks for the insight so far.
Cheers
Ben
      01-16-2012, 08:38 AM   #7
epiphone3
Drives: 2013 BMW X3 35i
The best thing I can suggest is to see what kits are available for the E90. The E90 has all functions discussed and may even have very similar brake system parts to the F25 X3.
      01-17-2012, 12:15 AM   #8
AtlM5
^this might be worth a try however I doubt it will be functional with the ECU...you could try looking for something with the same features and the 8speed tranny as it would be more likely to integrate with the ecu but unless you get somehting that is built specifically for the X3 you will have to worry about f/r bias because different cars have different weight distributions, brake dive, etc. which may cause the wrong wheels to lockup first and will throw off the bias
      01-18-2012, 12:38 PM   #9
Ant Man
Drives: E92 M3 Individual Edition
There's sure to be a different after market pad material out soon. Having said that if you replace the brake lines and add fluid with far higher boiling points it should give you better feel - as you suggested. If you experience brake fade you could always DIY a cold air fee tubing to the discs and calipers.
