      02-18-2019, 04:49 AM   #1
Minisi
Drives: 2008 e92 335i
VDC 2 module location.
Hi all,
As per title does any one know the location of where the vdc2 module is on a 2014 f25 please???
Thanks in advance.
      02-18-2019, 07:25 AM   #2
TheCoolX3
Drives: 2016 BMW X3 35i M-Sport
Open trunk
Disconnect battery
On the right side of the trunk you'll see a black plastic tub - remove that its a couple of plastic fasteners (You may have to remove the whole right side trim to get the bucket out)
Once that is out you should see the VDC incased in some foam
Remove from foam and unplug!
2016 X3 35i |M-Sport|Megan Racing Coilovers|FBO+|BM3|Jordan Tuned|Valvetronic Designs|
1998 750iL V12|2017 440i|2019 991.2 GT3RS Weissach|2019 Model X|...and some others
Instagram @TheCoolX3
      02-18-2019, 10:38 AM   #3
Minisi
Originally Posted by TheCoolX3 View Post
Open trunk
Disconnect battery
Thanks that’s great. Have just done this and found the module but mine doesn’t seem to be incased in a foam casing like all the other electrical components in the boot.
The vdc was changed by a local specialist but same fault has come back so wanted to check what he had done.
      02-18-2019, 10:49 AM   #4
TheCoolX3
May be a bad module or was not coded in correctly
      02-18-2019, 11:09 AM   #5
Minisi
Yeh I’m hoping it’s as simple as that’s dude. The bmw specialist is adamant it’s nothing to do with the work he has done or the module. I said the same fault has come up less than 100 miles after it has been fitted.
      02-18-2019, 01:35 PM   #6
TheCoolX3
What is the fault? Could possibly be one of the connections on the suspension struts are loose, I'd check those first.
      02-19-2019, 06:10 AM   #7
Minisi
Chassis error on the idrive. Specialist scanned and found vdc1 was to blame. He changed that and the fault has now come back less than 100 miles. I’m going to check the senators on the suspension later today. 👍
      02-19-2019, 07:39 AM   #8
TheCoolX3
Let me know how it goes!
      02-19-2019, 10:11 AM   #9
Minisi
Thanks dude. Will let you know 👍
