03-06-2018, 06:57 PM | #1 |
Rep 46
Need help narrowing Non Run Flat Tires for Wife (Live in FL, Drive to N AL)...
Okay, we decided to skip RFT after reading all the threads.
The car is 2012 X3 35i and currently has Pirelli RF which my wife finds too harsh/rough. Goal is smoother ride. From reading all of threads, the 2 models that seem to be most popular are: Continental DWS 06 Michelin Primacy My confusion is that the DWS are "Ultra High Performance" rating on Tire Rack but also have a UTQG of 560. The Michelin Primacy are "Grand Touring- All Season" and have a UTQG rating of 500. Needless to say, the car will not be pushed or used on the track. Mainly city driving in Tampa, FL with 2-3 trips per year to N. Alabama. What tire should I pick? Last edited by atwnsw; 03-06-2018 at 07:20 PM.. |
03-06-2018, 07:27 PM | #2 |
Rep 290
Check out the KUMHO LX platinum
I live 30 minutes from tire rack and just got these. Super quiet, great reviews and under 100$ each. I got the 245/50-18 |
03-07-2018, 08:59 AM | #3 |
General of the Space Forces
171
Rep 721
If she is looking for comfort over performance, first thing would be to get 18" rims if you don't already. They are a smoother ride on average over 19" or 20" rims with the same tires.
I would lean towards Pirelli Cinturato P7 All Season Plus, a Grand Touring All-Season tire. Supposed to have good comfort and low noise. Second choice would be the Michelin Primacy MXM4. |
03-07-2018, 09:37 AM | #5 |
Rep 362
Drives: 2016 X3 xDrive 35i
I would focus more on the individual tire characteristics than broad categories such as Grand Touring All Season vs. Ultra High Performance All Season.
Michelin Primacy has a comfort rating of 8.4 (ride quality 8.6) according to Tire Rack. Continental ExtremeContact DWS 06 has a comfort rating of 8.6 (ride quality 8.8). The Continental Tire is likely to offer slightly better ride quality based on these ratings. There are other tires you might consider. As najnad noted, the Pirelli Cinturato P7 has a better comfort rating at 9.0 (ride quality 9.1). You might also consider the Michelin Premier A/S with a comfort rating of 8.8 (ride quality 9.0). What are your plans to deal with a flat tire if you switch from run-flats? Note there are also run-flats that may offer better ride comfort than your OEM tires. Ride quality on the Pirelli run-flat according to Tire Rack is 7.2. Ride quality for the Michelin Primacy MXM4 ZP is 8.2 according to Tire Rack. Last edited by MichiganMike; 03-07-2018 at 02:31 PM.. |
03-07-2018, 09:38 AM | #6 |
Rep 11,843
Drives: MY24 G01 AW Msport
i have DWS06 on my X4, they perform well in any kind of weather.
03-07-2018, 02:51 PM | #9 | |
Rep 46
I purchased the Slime 70005 from Amazon for $30 which includes a tire compressor. In a perfect world, we would use the compressor to get us the rest of the distance (may require multiple stops if the leak is bad) to a tire shop. Next worse scenario, use the slime. Given that most stores, especially small towns, don't carry run flats (which would take a 1-2 days for delivery), my logic/hope is that they could repair the existing tire or have a regular tire on hand.... Since you can't repair a RF and we don't have a spare, I find the Non-Run Flats option more palatable. Last edited by atwnsw; 03-07-2018 at 03:02 PM.. |
03-08-2018, 01:15 PM | #10 | |
Rep 102
I think your plan is reasonable. I hope you never have to initiate it. I have a bit of good news. You can in fact repair run flat tires, as long as the damage is not too close to the side wall and as long as there is sufficient tread depth remaining. How close to the sidewall is permitted/legal, and how much remaining tread depth is sufficient varies by location and by repair shop. As always, it is best to err on the side of caution because we operate high performance vehicles in generally more aggressive ways.
03-08-2018, 04:18 PM | #11 |
Rep 377
Drives: 16 X3 28d/18 540d xdrive
If you really want a smoother ride on an X3 switch to 17" rims with 225/60 Bridgestone Driveguard runflat tires. 17" wheels from older X5 are inexpensive and are 100% compatible with newer X3 and tires run about $160 from Tirerack. I have a similar setup with my winter tires and I am in no hurry to change back to OE 18" wheels and tires come spring.
03-08-2018, 05:32 PM | #12 | |
Rep 362
https://www.tirerack.com/tires/tiret...jsp?techid=226 |
03-08-2018, 05:40 PM | #13 | |
Rep 362
http://x3.xbimmers.com/forums/showthread.php?t=588461 |
03-09-2018, 01:41 PM | #14 |
Rep 119
My local Tireshop told me DWS06 in size 245/45/19 does not meet F25 35i load rating?
Can someone confirm the axle weights and rating? |
03-09-2018, 05:01 PM | #15 | |
Rep 362
"The gross axle weight rating of this car is : Front 2447 lbs Rear 2844 lbs This is the maximum amount of weight your axles are rated to bear. So any tire with more load capacity exceeds what your vehicle can handle." http://www.bimmerfest.com/forums/sho...d.php?t=879463 The OEM tires likely have a 102 XL rating for a maximum load of 1874 lbs. This is higher than the 1653 load index for the Continental DWS 06 (98). However, the comment from the person at Tire Rack at the link above suggests the load rating of the 98 load rating is adequate for this vehicle. |
03-10-2018, 07:48 AM | #16 |
Rep 377
Mike,
In reading the link you provided, it appears that the only concern with 17" rims (from everyone including BMW dealers) is clearance. Assuming that a specific 17" wheels clears the brake calipers (and those from older x5s do), then 17" wheels and tires remain a viable option. |
03-20-2018, 03:50 AM | #18 |
Self Proclaimed Roundel Junkie
627
Rep 1,593
Just to add. I'm also running a set of non RFT tires. I'm on Michelin Pilot Sport 4S (definitely more performance oriented than you wanted)... That being said, I have road hazard from the shop I purchased at (Tire Kingdom, also in FL) and I have the BMW mobility kit. Its much more expensive than the Slime option you bought from Amazon, but its basically the same thing and comes in a nice carrying case. I've used the compressor many times on kids bikes, pool floats, etc... Luckily not yet for the vehicle.
Anyway, good luck, enjoy the smoother, quieter, and more fuel efficient ride on non RFT tires!
2018 F15 X5d Carbon Black/Nutmeg Individual- Oil Burner Tow Rig
2013 E82 1M3 Carbon Black/Black- S65/DCT Track Toy 2013 F25 X3 35i Alpine White/Chestnut- German American Family Hauler Past: '11 E91 335is, '11 E90 M3, '10 X5M, '14 328d, '03 330i Dinan3 ZHP, '04 330i ZHP, '12 X3 35i |
03-21-2018, 09:05 AM | #19 |
171
Rep 721
I recently switched to non-RFTs myself, Michelin Pilot Sport A/S 3+...but I wanted something more performance oriented than the OP. So far they are great, but its been less than a month.
03-21-2018, 09:46 PM | #20 |
Rep 234
Discount tire was recently running a special on the new General AS05 tire for 520 shipped with a 70 rebate in the 245-45-ZR19 size XL rated. Very similar to the Conti DWS but better dry traction at the expense of snow traction. Tire rack has these as the second best in their category. I have them on a GTI and my X3 and think they handle much better than my michelin rfts. Also these are 6lb lighter which means less unsprung weight for better handling and better braking and acceleration. But the DWS is a great tire and if money isn't an option the Michelin non rfts are awesome.
03-22-2018, 09:50 AM | #21 |
Rep 818
When I need tires next month probably going with the Firestone Firehawk Indy 500. I live in FL so I just need wet/dry traction, no snow. They're rated nothing but 5 stars and only $150 each for 245/45-19
03-23-2018, 04:20 PM | #22 |
Rep 34
Tires for FL and the south
Hi - I run BF Goodrich G-Force Comp-2 A/S Z rated - For Florida and the south with all of our rain - they're awesome - have yet to hydroplane with them and you always feel very planted and in control - had Michelin Pilot Super Sport which are great but not as good in rain and light off road
