05-06-2021, 06:07 AM | #1 |
Rep 8
Centre Console
Hi everyone
Does anybody have a video to show how to remove the center console between the front seats and to remove the I-drive controller. Need to clean sticky keys on it. Then also how to remove the "P" park button/lever. X3 2012 Xdrive20D Thanks Victor Last edited by VictorD; 05-06-2021 at 06:08 AM.. Reason: Detail on car added |
05-06-2021, 07:18 AM | #2 |
Rep 2,908
I don't think you really mean you want to remove the center console, which is the entire structure between the seats. To access the iDrive controller you just need to remove the decorative top panel - wood or whatever yours is. Luckily, that piece is as easy to remove on an X3 as any car in existence. No screws - just clips. Take a plastic trim pry tool and pry up at the back end of it by the center armrest. Once you pop up the rear clips it just lifts up and back.
tracer bullet2417.50 WagonR293.00 |
05-09-2021, 07:01 PM | #4 |
Comfortably Numb
578
Rep 654
Drives: '18 x1/'13 X3/'06 330i
l have used a product from CRC, electrical contact cleaner to free up sticky buttons in the I drive controller. l believe most auto parts stores sell a version of it, comes in an Aerosol spray with the small tube similar to WD-40. Sprayed a small amount between the button and the housing with success. After spraying did rock the switch back and forth a couple of times and let it set. after a couple of hours switch works like new.
06 e90 330i/Alpine White/Terra Dakota
13 F25 X3 xDrive 35i/Black Sapphire Metallic/Oyster Nevada 18 F48 X1 xDrive 28i/Black Sapphire Metallic/Black SensaTec |
05-10-2021, 08:51 AM | #5 | |
Rep 2,908
Tags |
f25 i-drive cleaning sticky |
