04-21-2021, 12:40 PM | #1 |
Rep 43
2014 X3 X28i malfunction
All of a sudden i have 4 malfunctions or errors,
Level control, SOS, Front Collision, Driver assistant. I also saw the configuration files error message too. (1) Is this battery related? Still have old battery, and was low in the winter (2). Can I remove the battery and reconnect to reset the message? (3). Do I need to recode the battery if I buy the same battery? Thanks! |
04-21-2021, 05:47 PM | #2 |
Rep 2,547
You need to properly test the battery health prior to diagnosing any errors or you're wasting your time. You need to register the new battery if you install one of the same exact capacity, this has been discussed many times if you do a search in the forum.
04-21-2021, 08:22 PM | #3 |
Rep 43
The battery is fine. 12.2V when the car is not running and 15.5V when it's running. Vehicle configuration inconsistent. Check...showed up along with others. I resetted the software today, it did not solve the problem. One more error: instrument panel malfunction also showed up. Please help!
04-21-2021, 11:02 PM | #4 | |
Rep 2,547
What did you do to reset the software |
04-25-2021, 12:16 PM | #5 | |
Rep 43
Thanks a lot for your help. |
