03-17-2021, 01:55 PM | #1 |
Rep 231
Drivetrain malfunction - anyone seen these codes?
Hey Everyone,
I have a 2013 X3 N55, about 92k miles. So i got a drivetrain malfunction back in Mid February where i was greeted with a less than smooth start up, the high idle was choppy and then the codes came - the codes as per my Foxwell scanner were: 120408 - charging pressure control switch off as consequence 131508 - Variable camshaft timing control (VANOS) intake. Cold start not controllable. I cleared the codes at that time and was fine for just about a month (although admittedly i didnt drive that much during that time period). A couple days ago - i got the drivetrain malfunction again same 2 codes plus 1 more. 10BA40 - outside temp sensor plausibility. Ambient temp greater than model? 120408 - charging pressure control switch off as consequence 131508 - Variable camshaft timing control (VANOS) intake. Cold start not controllable. For now, i swapped the vanos solenoids (they looked clean, and i cleaned them up with brake cleaner just in case). So for now i want to see if the codes come back if it will swap over to Vanos exhaust code. If not i may check into the Vanos servomotor, i REALLY hope i dont have the shredded vanos bolts. Although mine is a 2013 X3 N55 so it appears i am outside the recall that affected 2011 to 2012 i believe. Another piece of information, well before i threw the drivetrain malfunction, ever since i got the X3, on restart when warm i would sometimes get a hunting/suring idle like 700 - 900/1000rpm and then when in gear it would also surge. But i never threw any codes previously. Anyone come across something similar? Thanks! Rube |
03-18-2021, 07:35 AM | #3 |
Rep 231
I replaced all 6 plugs with NGK and Delphi coils probably around 8k miles ago. If you're thinking misfire, would that usually be accompanied by a misfire code?
Also wanted to add, the surging idle was present when i first purchased the X3 at 82k miles, which is why i ended up replacing the plugs and coils. That didn't have any effect, the surging/fluctuating idle on a warm restart still persisted (although not every single time. very strange). |
03-18-2021, 01:52 PM | #4 |
General of the Space Forces
171
Rep 721
smoke test, look for vacuum leak
03-22-2021, 04:34 PM | #6 |
Rep 2
Drive train malfunction
So... apparently BMW X3 model years 2013-2015 are made with plastic timing chain guides. Which, of course, plastic gets brittle and breaks.....
I have a 2013 X3 with 62,000 miles on it. In February 2021, I received the "drive train malfunction error". Took it to the dealership and had to have all this work done.... $5500.00 worth of work to replace parts, etc all due to the timing chain guides. 3/11 - less than 600 miles since I picked up my newly repaired car from the dealership - I got the "drive train malfunction" error again... This time it is a Intake cam solenoid. The dealership fixed it, took it for a test drive, and it died on them.... and now I need a new motor My advice is - anyone with a 2013-2015 X3 - GET RID OF THEM NOW!!! |
04-25-2021, 05:48 PM | #7 | |
Rep 231
